Looking for a quality balanced input to unbalanced output circuit, op-amp or discrete or whatever.
The best advise here will be appreciated. The project is for a power amp and I would like to have both types of inputs, switchable or not, XLR input and/or "RCA" type input. Small is good, low parts count is good, but best quality and least signal degradation is the prime directive. (The name balun, of course referes to the old antenna balun for conversion of 300 ohm to 75 ohm antenna cables, balanced to unbalanced ... bal ... un ... but most of you already knew this.) |
#2 | ||
Cheers, Shawn. |
#3 |
... something that didn't have a transformer ... but that is a very interesting link ...
Thanks Tom! |
#4 |
Hello FastEddy
You could take a look at analog devices SSM2143. It is a differential receiver intended for audio use. http://www.analog.com/en/prod/0,,765...SM2143,00.html I have never used this part myself, so I cannot tell you anything about sound quality. If you want to look around then look for Differential receivers or Instrumentation amplifiers. I hope this helps Janus |
#5 |
Did it Himself
I can supply you with a layout for a quality balanced input receiver, uses op-amps so no problem with obsolescence
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 |
... or some such.
I now have a "junk" Crown XLS 202 amp that I have run up on the rocks and gutted for its usable cargo ... keeping the power switch, output speaker HF filters and some other parts and the torrid transfoirmer & wiring & hardware (secondaries are +/- 48 VAC & +/- 18 VAC). I am installing a couple of AV400 kit boards and PS filter boards ( http://aussieamplifiers.com ) ... If your circuit is a part of a complete pre-amp (or can be made as such) then ... super. As for the op-amps, I will brew up a +/- 24 VDC linear supply for your "balun" and other circuits. (The Crown case has gobs of room) ... |
#7 |
J. Honoré: " ... a differential receiver intended for audio use. http://www.analog.com/en/prod/0,,76...SSM2143,00.html ..."
Great device. Analog Devices has been doing the good stuff for decades, always a reliable resource. ... Thanks. |
#8 |
Did it Himself
The circuit is just one of many that I am getting round to putting on my website. It's a standalone board, fairly small. Might even have a board or two kicking around...
As for PSU, the one where I 'met' you recently while helping the guy to develop his, should be OK and easy to adjust for a different voltage, or there's always my own as I'm sure you know.
#9 | |
| DIY RCA - cat5 balun help | rb1980 | Parts | 6 | 28th July 2009 04:51 AM |
| High Quality X/O Parts | nelsondog | Swap Meet | 0 | 25th August 2006 05:02 PM |
| DIY Balun | george a | Digital Source | 7 | 14th October 2005 01:21 AM |
| Low wattage, high efficiency, high quality? | Nordic | Multi-Way | 5 | 4th September 2005 11:12 PM |
| High Power High Quality Digital Amp | aspycaudio | Digital Source | 0 | 6th December 2003 09:49 AM |
| Page generated in 0.10590 seconds (79.02% PHP - 20.98% MySQL) with 10 queries |
