Nees advice on preamp psu.
Old 12th December 2002, 05:46 PM   #1
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Default Nees advice on preamp psu.
Alright, I'm planning on building an RIAA MM preamp using 2SK170 JFETs with resistors and not CCSs. I just need advice on what type of psu I should use, basically only two JFETs per channel and they'll run of +36V. I gather they'll have to be regulated, but would a discrete regulator be that much better than say a integrated shunt one like the TL431? If so I haven't seen any suitable discrete designs, I was thinking maybe a pi filter followed by a discrete zener shunt regulator. Or would a series regulator be better? Or should I even bother with the pi filter? Maybe just a C filter, if so how large? So many questions, I've never built a discrete transistor circuit that uses resistors instead of CCSs so I just don't know how quiet the suply has to be, thanks as always for any replies though.
Old 12th December 2002, 10:13 PM   #2
JoeBob's Avatar
No one has any advice?
Old 13th December 2002, 12:14 AM   #3
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
maybe this can give you some ideas?
http://www.passdiy.com/pdf/pearlphono.pdf
Mads K
Old 13th December 2002, 01:22 PM   #4
Jeff R is offline Jeff R  United States
In general, design for a much "quiet" as you can - especially in a preamp stage, as any noise here is going to be amplified by everything else. I even like to see an LC filter from the transformer to reduce current spikes and, thus, noise.
The pearlphono design looks pretty good and, with some tweaks, should work fine at 36 volt output. Some of the newer integreated circuit voltage regulators ought to work pretty good, too, and should give lower a lower Zout and possibly better hi frequency response. A good old emitter follower with a zener on its base ought to work good for a low current amp as well.
So many choices!
Nees advice on preamp psu.Hide this!Advertise here!
X0.2 Preamp advice & circuit Barry1 Pass Labs 19 2nd June 2011 01:46 PM
Need advice on two preamp kits. Nay9 Tubes / Valves 3 21st June 2005 10:04 PM
AV Preamp advice... eRiCdWoNg Everything Else 0 9th January 2004 03:46 AM
Need advice on Dual 505-2 cartridge and preamp minaret Analogue Source 1 10th December 2003 10:15 AM
op-amp based preamp advice needed Adam Solid State 11 18th November 2002 02:14 PM
