Old 5th September 2006, 09:30 PM   #1
Send a message via Yahoo to mikelm
Default prototype PCB's in the US
Can someone in the US recommend a company for prototyping PCB's in the US ( where I now live )
I have never made a PCB before so I may need some technical help from the PCB manufacturer
I use UK programme called PCB wizard ( it has gerber & NC drill export )
A company called "quality PCB service" quoted me $166 for 2 x 8" x 11" single sided boards. This is for etching, tinning, drilling & cutting only. does this sound reasonable ? I thought it was quite expensive.
...and the disclaimer saying that if they can't read my files it's my responsibility was not that re-assuring.
thanks
mike
Old 5th September 2006, 10:32 PM   #2
With PCB manufacturing, there is a trrade-off between how fast you want your boarsd and price. The cheapest manufacturers I have found are:
www.batchpcb.com
www.barebonespcb.com
As their name implies, they provided the lowest prices, but you won't get things like a silk screen. Their basic packages ARE double-sided.
$166 seems a bit high for one single-sided board. Some PCB companies are not "geared" for making just one board, and thus they will charge you more when you only order one board.
Old 5th September 2006, 11:26 PM   #3
I can offered you $99 for 200 in2,
single side,
component sillkscreen,
1 oz cu
tinned
solder resist,
provide me with gerber for silkscreen, trace & pad, bottom resist, drilling.
+ shipping charges
Old 5th September 2006, 11:27 PM   #4
Arius is offline Arius  United States
Speaking from one happy customer of www.pcbfabexpress.com, feel free to give them a try. I use them for both work and personal prototyping.
They're cheaper than the 2 sites mentioned above.
E.g. $20 per board for a 40sq inch PCB, min order 5 pcs. 5-day quick turn. Solder masked and silkscreened.
Old 6th September 2006, 01:20 AM   #5
Thanks for your replies.
My original quote is now reduced to $141 on a 5 day turn around...
and I made enquires with the other companies.
AMP7 prototype peranders Class D 9 25th April 2009 05:41 AM
my new prototype zilog Power Supplies 5 25th September 2008 05:03 PM
prototype speaker lazenna Multi-Way 4 25th July 2008 04:15 AM
BassBox Pro, prototype ? REALFLEO Multi-Way 76 16th July 2008 09:23 AM
Page generated in 0.08234 seconds (66.61% PHP - 33.39% MySQL) with 10 queries
