I have more than one car audio amp that goes into protection mode as soon as powered up. The amps are various brands, but look pretty much alike inside. I can send pics, if needed. I am looking for help to repair this fault.
#2 |
Hi masterchief
This is a frequent problem on this amps. The first thing are to determinate where is the fault. Separate the SMPS power suppli and connect a variable laboratory dual power supply and power on :if the power amp work,the fault is in protection circuit.Check them and substitute the fault components. What is the protection circuit that is on? power supply or power amp? |
#3 |
I think it is the pwr supply that is going into protection, because there are no amps showing on my pwr supply meter. It appears to be a PWM type system with a toriodial transformer, presumably to raise rail voltage. There is a IC that I think tests the pwr to the amp and if there is a fault detected, it bypasses and lights the protection light. I would like to bypass this, but am not sure how. Maybe if I post some pics, someone would recognize the circuit config.
#4 |
Hi masterchief,
Parsecaudio told you how to do this. I use the same method myself. Power up the amp section alone and make sure it works properly, then work on the supply. Never bypass the protection, there is a reason for it. -Chris |
#5 |
Thanks for the help, guys. I am going to have to try a different approach. The only bi-polar pwr supply I have is 15v. I am thinking of testing the switching mosfets in the pwr supply, and the diodes. masterchief
#6 |
Make sure your power supply has enough "moxie" (Current). Sometimes there is no such thing as "soft-start" and the amp's supply will have steep current requirements to get whizzing. This may make your bench supply' voltage drop. This can start an endless cycle of amp trying to start, power supply current limiting, amp trying to start, etc, etc.
".........These go to eleven" |
#7 |
Hi mrshow4u,
That's what the car battery I've seen on many benches is for. Masterchief, try to run your amplifier section on -+ 15 VDC. It may work. -Chris |
#8 | |
I'd rather have the electrolytics blow up in my face.
#9 |
Hi mrshow4u,
Hey! I don't use a battery. I have a few supplies. One is good for 25 A and it's regulated (they all are). There is a 5 A and a 10 A somewhere too. I use a 3 A on the bench normally. I also have a 2.5 A bipolar and a 0.5 A bipolar (HP) for checking the amp sections. Batteries do all kinds of nasty things on a bench. I'm just saying I've seen them. -Chris |
#10 | |
edit: "They're all regulated". Is that true? I've got this thing from Tripp-Lite and I rember looking inside and just seeing: Big-fat transformer, parallel bridges, and pretty hefty filters. That was pretty much it. When I've VariAc'd the supply, it seems to just ramp smoothly with no apparent regulation voltage. I didn't specifically try to see if the output voltage would limit before the VariAc got to ~130VAC.
| C-Audio RA2000 Protection LED | Ovation | Solid State | 31 | 7th November 2011 06:45 AM |
| Audio protection circuit for microprocessor ADC? | Neil_J | Digital Source | 1 | 26th June 2007 07:33 PM |
| over-temperature protection for audio smps | zilog | Power Supplies | 5 | 19th January 2007 01:51 AM |
| Troubleshooting Audio and Video Noise | Arius | Parts | 0 | 25th May 2006 09:45 PM |
| Over-current protection in Audio IC Output Buffers | ppl | Solid State | 1 | 21st October 2003 06:35 AM |
| Page generated in 0.11759 seconds (76.12% PHP - 23.88% MySQL) with 10 queries |
