Old 5th September 2006, 06:16 PM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default poweramp what transformer to use?
iam not sure on what transformer to use right now its got a 48vct 2.0 amps with with a va rating of 96 if i increase the va rating what will happen beside the amp going up i wana keep the voltage the same maybe go up by no more then 10 volts when amp is turn on the voltage reads 69 if the mj15003 are not hook up when they are it reads 56 volts i am not sure on how hi to go with the va
Old 5th September 2006, 06:24 PM   #2
paulb is offline paulb  Canada
If you amp is wired the way the schematic shows, you don't have a ground reference from your power supply. You want a +/- supply, not a single-ended one. Your power supply should look like Fig. 1 here:
http://sound.westhost.com/psu-wiring.htm
Old 5th September 2006, 09:57 PM   #3
Default powersupply
this is the way I have the power set up
I wana keep the amp to
350 watts
when i measure the speaker with an ohm meter it say 12 v 6 amps iam hoping a higher va rating will do this but iam not sure
Old 6th September 2006, 01:45 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Why not go for 10 amps,for the transformer???
YAP - Yet Another PowerAmp syn08 Solid State 315 4th October 2011 11:39 PM
Page generated in 0.06613 seconds (71.74% PHP - 28.26% MySQL) with 11 queries
