Old 3rd September 2006, 08:13 AM   #1
Default help me choose my first amp project
Can you guys recommend the easiest amp to build. I don't care how much gain or how it sounds but I would like to require as little parts as possible. I am using this project to help me learn more about electronics and audio components. Links, pics or easy intrustruction would be appreciated but just the name would suffice. Thank you in advance.
Dance like no one's looking
Old 3rd September 2006, 08:50 AM   #2
djk is offline djk
djk's Avatar
Start out with something from the chip amp forum.
You will learn about assembly, power supplies.
After you get that done and want something a bit of a challenge, do an ESP P3A
http://sound.westhost.com/project03.htm
Poke around at his site, lots of good info there.
Old 3rd September 2006, 07:26 PM   #3
Which one from the chip amp forum would you consider the easiest t build? Can you give me a specific name or model?
Old 4th September 2006, 12:38 AM   #4
Hi stonedfenix
there was my first amp in 1981 with VS=12 V DC...
Old 4th September 2006, 01:44 AM   #5
Thank you parsecaudio for your design but since I am a very low level noob I have trouble understanding it. Maybe you can explain how to make one in more detail. Or can you post a link with detail or tell me what is this amp called so I can look for instructions.
Old 4th September 2006, 09:33 AM   #6
Hello stonedfenix
I understand your problem...
The simpler way to built a circuit is to buy a complete kit with components ,circuit board and instruction in some store nearest to you.
Old 4th September 2006, 01:30 PM   #7
http://www.audiosector.com/lm4780.shtml /sreten.
Old 4th September 2006, 05:52 PM   #8
rkevans is offline rkevans  United States
rkevans's Avatar
The 'chipamp' from AudioSector above is a great first project.
Another fun project (and cheap) is the CMoy headphone amp. It'll fit into an Altoids (TM) container with a 9v battery. Not quite as easy to build since there are no prepackaged kits available, but look at http://tangentsoft.net/audio/cmoy-tutorial/ for a tutorial.
You can build these together and use the CMoy as a preamp for the ChipAmp...
Rick
Old 5th September 2006, 02:48 AM   #9
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Hi,stonedfenix.First you have to decide which type of project do you want to dealing with,discrete or ICs.
Old 5th September 2006, 07:53 AM   #10
djk is offline djk
djk's Avatar
I would go with something from either Brian or Peter, they have worked together on some of their projects. Go review both of their sites, look at the project galleries to get some ideas, and buy some sort of kit from either of them.
new ChipAmp.com website - LM4780 kit and more
AudioSector-chip amp kits, dacs, chassis
Trying to choose a project... isaacc7 Tubes / Valves 8 7th August 2010 01:15 PM
Help Me Choose project Please! sifis_samos Multi-Way 44 4th August 2009 03:51 PM
Help me choose a Tube Amp. Project Ysabban Tubes / Valves 36 20th January 2005 10:11 PM
Help me choose project Vladco Pass Labs 3 23rd August 2003 10:27 PM
Help me choose first project greg7 Solid State 9 29th April 2003 02:01 PM
Page generated in 0.09779 seconds (77.99% PHP - 22.01% MySQL) with 11 queries
