Old 3rd September 2006, 12:38 PM   #1
gcohen is offline gcohen  Israel
Default Hafler DH-220
Hello all,
I have an Haflar DH-220 with burnt output mosfets.
Since these are quite expensive I wonder if someone have tried
to put an IRF devices, e.g., IRF240 and IRF9240 instead of the
2SK134/2SJ49 .
Thanks in advance,
Guy
Old 3rd September 2006, 01:18 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Guy,
Won't work. The bias characteristics are different. The IRF devices are completely different beasts.
-Chris
Old 3rd September 2006, 01:19 PM   #3
edl is offline edl  Hungary
edl's Avatar
Default Re: Hafler DH-220
Originally posted by gcohen
Hello all,
2SK134/2SJ49 .
Thanks in advance,
Guy
don't even try these IRF devices.
Let's use the 2sk1058/2sj162 pair.
Old 3rd September 2006, 02:49 PM   #4
gcohen,
Did you test and check your present Lateral Hitachi MOSFETs? How do you know they are burnt? These are very rugged devices. Tell us more.
But, the other posters are correct, you can't use vertical MOSFETs (IRF devices) to replace Lateral MOSFETs (Hitachi).
Profusion (UK) sells replacements for Hitachi devices. Go here:
http://www.profusionplc.com/static/subsites/exicon.htm
But, they must be matched ±10% on Vgs and matched pairs can get expensive.
Old 3rd September 2006, 05:49 PM   #5
jackinnj's Avatar
Hitachi doesn't make the Lateral MOSFET's anymore -- they're done by Renesas -- http://www.tech-diy.com/LATFET.htm -- shameless plug
Old 3rd September 2006, 07:06 PM   #6
Default DH-220
Hello all,
Thanks for your help. I was affraid that the IRF parts will not
work. There is a guy who says that he did such a modification
in his SCS amp, please see here:
http://aga.rru.com/TechTips/disp.cgi...owerFETRepl.tt
I know that one of my 2SK134 in my Hafler is burnt since it
is shorted between source and gate.
Surprisingle, I do not find any other shorted component.
Thanks again,
Guy
Old 3rd September 2006, 07:22 PM   #7
I have 50 pairs of 2SK175 / 2SJ55 Hitachi MOSFET`S. They are the same, only difference is higher voltage rating and higher current capability. These are new and unused, and they are all from the same batch, so there is no need to match them.
Roar
Old 3rd September 2006, 07:24 PM   #8
anatech's Avatar
Hello Guy,
I've tried on different amps with varing results. I'll rephrase my earlier statement.
As best, they do not work properly, worst case they will go into thermal runaway and cook themselves to death.
Don't do it. Jackinnj gave you a workable solution.
-Chris
Old 4th September 2006, 08:06 AM   #9
Hello all,
Thanks again for your help.
If I will buy replacements, I will buy a 2SK135/2SJ50 and not
2SK134/2SK49 - This will force me to buy four transistors.
and to accept the differences between the two channels (since
the other channel is original 2SK134/2SK49).
The price of two matched pairs start to be very close to the
price of buying another Hafler DH-220 in ebay!
So, I will see what to do. Thanks anyway.
Guy
Old 4th September 2006, 10:32 AM   #10
edl's Avatar
You can use the buz900/buz905 or the buz901/buz906 pairs too.
Good luck,
Hafler... tomtt Everything Else 0 11th May 2006 02:34 AM
Hafler PC-10 help..... burntfingers Solid State 5 22nd March 2006 12:33 AM
Hafler DH-225 and P-230 Bogie Solid State 0 11th February 2005 12:03 AM
hafler amp or pre-amp larryg Swap Meet 0 10th March 2004 01:39 PM
Hafler DH-120 and 220 ? Tino Solid State 0 11th January 2004 11:14 PM
Page generated in 0.12201 seconds (70.30% PHP - 29.70% MySQL) with 10 queries
