Old 5th September 2006, 11:48 AM   #41
4fun
I agree with you.
A simple fuse is not an adequate protection for a loudspeaker, perhaps in case of use a particularly strong speaker with a low power amp, but this is a nonsense.....
Old 5th September 2006, 02:28 PM   #42
anatech is offline anatech  Canada
anatech's Avatar
A fuse in series with the output is a bad idea for both protection and fidelity. If that is all the designer can come up with, it's time for him to go back to school, or give up design work.
Andrew,
A fuse outside the feedback loop to the speaker is a deliberate attempt to introduce distortion to the signal.
I'll second your "Don't". Inside the feedback loop, you now have to fight an additional non-linearity.
I think the first thing to do is mute the input (works for a DC fault out of a preamp) and disconnect the energy source from the load. This may take the form of a crowbar, relay or shut down (as in a Carver). Carver's scheme worked very well, and is my favorite for being able to preserve sound quality while limiting damage to both the load (speaker) and the amplifier circuit. Crowbars will work but I have seen them cause fatal damage to the circuit board in large amplifiers.
-Chris
Old 5th September 2006, 02:44 PM   #43
Bgt is offline Bgt  Netherlands
Originally posted by latala
To me the best method is to bite the bullet and use a high power Relay/Contactor.
I
Toatally agree, never had probs. with relays for speaker prot.
Use a double finger 1 so you minimize failure.
Kind regards,
Bert
Old 5th September 2006, 08:26 PM   #44
AKN is offline AKN  Sweden
Enjoy good sound
AKN's Avatar
Anatech,
That damage itself would indicate a design error more than the choice of protection circuit I think.
/ Anders
Old 7th September 2006, 09:30 PM   #45
Ok hello again. I have now built this circuit, but i got some problems. I forgot camera so no pictures yet
Schematics again:
http://files.upl.silentwhisper.net/u...tLayout1.1.pdf
First of all. The "Sensing" circuits works fine. It doesn't react to 5Hz 30Vampl. (sinus). That was the lowest i could test. But to DC voltage it reacts instantly, LED lights up and the 12V that was over the the zenerdiodes goes away. It keeps in this mode for about 10sec after DC is cut from input. Then the LED fades out and 12V goes up again.
The problem is that the mosfets never cuts when voltage over zeners goes away. It's still voltage on the Drain. When I measure voltage Between Drain and Source in normal mode, it was about 0.4mV (With 1kR to ground) but in protect mode (when voltage between D->S should be V+->Gnd) It's instead 0.6V and current still flows.
Can this be because there is a diode forward biased inside the mosfet?
The datasheet for IRF9540 http://pdf1.alldatasheet.com/datashe...L/IRF9540.html
It shows a diode there..
Hmm. Can i swap the 9540 with the 540 to get rid of this problem? or must P-mosfets be used with positive voltages?
Old 8th September 2006, 05:51 PM   #46
Enjoy good sound
AKN's Avatar
Hello!
I am a little worried about output from that last transistor whose emitter is connected to V+
In nomal mode everything is fine, transistor after is conducting.
But in protect mode collector is free floating and therefore base on transistor after is not defined. Maybe a pulldown from collector would help?
/ Anders
Old 8th September 2006, 06:02 PM   #47
anatech's Avatar
Hi 4fun,
This has happened in some large commercial amps in the 600 W range. Each was a mono block, not switching. Conventional amp.
Big, wide areas of foil were reduced to scorch marks and sputtering. Legs were blasted off transistors. Evidently, it had a really good power supply.
The only thing one can say is that at really high power levels, when something goes wrong, it goes really, really wrong! Quickly, I might add. If it's any conciliation, the (large) triac was also transformed into a fancy bit of wire.
-Chris
Old 8th September 2006, 06:16 PM   #48
Enjoy good sound
AKN's Avatar
Hi anatech!
But crowbar circuit on this powerclass that FritZell is making should work if properly sized I think.
Yep, I can agree that high currrent can make big mess.
At least speaker saved
Btw, Remember Crest amps from VS series that leaked elecrolytic on pcb, damage could vary from somewhat damaged pcb to total disaster.
/ Anders
Old 8th September 2006, 06:26 PM   #49
Hey.
Aha this is true. I shall put, say a 100k to earth from collector. But this can't be the problem since the 12V Vgs goes away when the last Bc556 shuts off. There is something weird with these mosfets. They don't shut off when there is no Vgs . Instead there is a voltagedrop of 0.6V from Drain to Source (with load)
I'm quite lost here...
Picture:
http://files.upl.silentwhisper.net/u..._Dcprotect.jpg
edit: I think i found the error. Will update soon.
Old 9th September 2006, 10:47 AM   #50
Ok the problem was that I had shifted Source and Drain on the PCB layout . The circuit works just perfect now!
LM3886 circuitry jmillerdoc Chip Amps 3 5th June 2009 01:25 PM
amp goes to protect, why? eeyore757 Subwoofers 6 22nd March 2007 12:29 AM
MCU controlled DC Protect for SKA gbyleveldt Solid State 3 12th October 2006 07:55 PM
About circuitry design, etc... J_Starner Parts 16 5th June 2006 02:30 AM
Using DC instead of Ac for some control circuitry filholder Chip Amps 3 2nd July 2005 04:53 PM
Page generated in 0.12144 seconds (81.14% PHP - 18.86% MySQL) with 11 queries
