hi!
Here is my own idea. It is very useful when testing building amplifiers. Adjustable TO3 Active PowerResistor Some details: - Like 10-50 Ohm - Max power ~20 Watt - Discrete transistors Op-amp as comparator - Compares adjustable reference leg, including potentiometer - with TO3 power leg, including one 1 Ohm power resistor Connections: - RED +voltage - BLACK 0 Volt - GREY current sense, gives a reading 1.00 Volt for 1.00 Ampere Enjoy and build the same yourself. Mine is for DC applications. Was originally used, to see how much a transformator voltage would drop at different load. Used as variable load resistor. Next project could be for alternate current, AC. Which could be more useful for some amplifier testings. Here is picture:
lineup |
#2 |
here
You can see how I attached TO3 at bottom. I have used some isolation material between control circuit and power transistor. Gives a little both electrical and temperature separation. Power transistor is a TO3 BUX39 which I from some old electrical junk I have found and carried home. For free, of course! Same goes for the small signal transistors. They are taken from old circuits - reused.
lineup |
#3 |
Well, it would be difficult for us to built it if we don't have the schematic
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#4 | |
a reference current with the power current? It is of no more hardship, than comparing a reference voltage with a 2 resistor voltage sense, like when using Voltage regulator. Of course for all those not familiar with this technique there is a very small amount of basic op-amp knowledge to find out. janneman. But this is an old circuit I built maybe 10 years ago. My papers used to calculate and design this circuit are somewhere in some pile of papers somewhere in my stuff. If they arent thrown away. From my photo, some clever and more experienced diyaudio member, that really understands my concept, may easily get the circuit, including most resistor values. I remember I tried to make the circuit only have some % current consumption compared to total, to make the current sense (GREY wire) be reasonably correct. And so give a good value for actual resistance, in Ohm. R = Voltage across circuit / Current The current sense, as told above, gives a reading 1.00 Volt / 1.00 Ampere. regards lineup
lineup |
#5 |
Wow.
Waiting ten years to publish. Talk about "hiding your light under a bushel". You would never survive in academia. |
#6 | |
Jan Didden
#7 |
I see. No problem, okay. Otherwise, I am a bit lazy, you see and I already have a working active power resistor circuit so my motivation for building another one is = 0, zero. Anybody who would like to have this and think it would be of help and use will find out and build. Some even better more versatile circuit than mine, most probably. The basic concept and idea will be just about the same. Like for other active loads, pure resistive or not. It is nothing new. My topic is to show how one can do. Present the idea of using a variable PowerResistor. Somebody surely can benefit from this topic. ================================== For hobby designers willing to do some work of their own ( not for copy-cats ) this third image might be helpful, too
lineup |
#8 |
I donīt get why you use comaprator, when you need linear regulation, not two-state regulation. Can you explain?
#9 |
One polarity transistor for AC using ? Are you wizard ?
#10 | |
if the AC statement is true then he really has been Quote:
regards Andrew T. |
| Variable frequency active crossover | FrankDIY | Solid State | 22 | 4th July 2009 03:30 PM |
| active crossover state variable filter | les winter | Multi-Way | 0 | 23rd June 2009 01:31 PM |
| Circuit for variable phase 0-180 control for active L/R xover | georgehifi | Solid State | 4 | 20th September 2006 09:55 AM |
| Behringer DCX2496 I want to try active biamping using it as the active xover. | georgehifi | Digital Line Level | 3 | 15th August 2006 07:46 AM |
| DIY active variable sub x-over? | darkmoebius | Subwoofers | 6 | 21st June 2005 03:39 PM |
| Page generated in 0.12229 seconds (82.44% PHP - 17.56% MySQL) with 11 queries |
