Old 2nd September 2006, 05:41 AM   #1
Tre' is offline Tre'  United States
Default Biasing a Adcom GFA 585
I talked to Adcom and was told 24mv between test points. That puts 36ma. of current through each output transistor. With a +/-80VDC rail there will be 2.88 watts dissipation per output. There are 20 output transistors total. This thing is going to get hot. Does this sound right to you?
Thanks...Tre'
Old 2nd September 2006, 06:32 AM   #2
EchoWars's Avatar
Lukewarm.
But...depends on the heatsink. I'd think that if it got hot just idling, that the heatsink would be seriously undersized.
Old 3rd September 2006, 12:38 PM   #3
The heatsinks are huge. It doesn't get hot, just warm. I'm used to cold SS amplifiers.
http://gon5.audiogon.com/i/c/f/1156611494.jpg
This is a pic of the 555 but the heatsinks are the same.
Old 3rd September 2006, 01:17 PM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi Tre',
That amp runs warm, but not very warm.
Did you follow the heat soak procedure before setting the bias?
-Chris
Old 3rd September 2006, 05:32 PM   #5
"heat soak procedure"?
Old 3rd September 2006, 06:34 PM   #6
anatech's Avatar
Hi Tre',
Yes. Run the amp at about 1/3 power into 8 R dummy loads for 20 min or so. The heatsinks will be very warm. Allow the amp to cool and the bias to settle down and stabilise. If you make a correction, allow 1/2 hour and check again. The top cover should remain on except for when taking measurements.
-Chris
Old 4th September 2006, 08:28 AM   #7
Chris, thank you for that explanation and all your help.
Tre'
SWR biasing need help... spirus Instruments and Amps 4 23rd November 2006 08:58 PM
low-biasing or high biasing in Class-AB amps Workhorse Solid State 124 18th October 2005 04:45 AM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 08:09 PM
SE OPT's & Biasing eeka chu Tubes / Valves 45 5th April 2004 10:54 AM
Page generated in 0.06690 seconds (83.00% PHP - 17.00% MySQL) with 10 queries
