Banned
hi
what is ripple current of a capacitor the one quoted in the ratings of a capacitor john |
#2 |
A power supply may draw constant current but the capacitors will charge only at the peaks of the incoming AC, so the charging current is much higher but shorter time, this is the ripple current. |
#3 |
the ripple current is responsible for most of the heating in a smoothing capacitor. The ripple rating varies with ambient temperature. Keep your capacitors COOL. Locate then away from hot heatsinks/sources and provide ventilation. You can use PSUD11 to investigate the ripple current in your proposed application, but do try to use as little of the permitted rating as possible. Multiple parallel caps offer a solution to high ripple currents but have other downsides and a few upsides.
regards Andrew T. |
#4 |
Enjoy good sound
Specified ripple current capability on a capacitor is specified in Arms, peak currents can be higher.
/ Anders |
#5 |
this will give you an idea of what ripple-current rating your caps will need
http://www.duncanamps.com/psud2/index.html
All this radio needs is a fuse |
#7 | |
#8 |
Banned
Hi and thanks
i still dont understand it, i know it relates to ripple but why is it useful, how do you apply it to power supply design high ripple currents c's are they better than low ones? thanks john |
#9 |
high ripple capacity rating is better than low ripple capacity rating. Using less than the ripple capacity rating is better than using all the ripple capacity rating. Overstepping the ripple capacity rating is dangerous (if continued for more than a brief moment).
regards Andrew T. |
#10 |
All caps have a finite resistance. Typically it is called ESR - equivalent series resistance. The power loss is I^2 * R and the power heats up the cap. The temperature rise is a function of the thermal resistance (from the cap hot spot to the surrounding air) and the life of the cap is strongly related to it's hot spot temperature. So, in general, lower ESR make for longer life.
| Ripple current ? | woody | Solid State | 2 | 12th January 2009 10:09 PM |
| ripple current calculation? | AndrewT | Power Supplies | 5 | 30th January 2007 04:24 PM |
| Ripple current in capacitors. | beppe61 | Power Supplies | 5 | 3rd September 2006 11:37 AM |
| ripple current calculation | metebalci | Parts | 1 | 24th July 2004 09:10 PM |
| psu problem / ripple current / esr | metebalci | Solid State | 3 | 30th April 2004 09:56 AM |
| Page generated in 0.10712 seconds (75.64% PHP - 24.36% MySQL) with 10 queries |
