Hi all,
Please can somebody tell me if its safe to use a PC PSU to pernamently run a car sub amp,whilst I wait for funds to buy a indoors amp? I did search but want to make sure its safe to do so. Thankyou
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi |
#2 |
As long as you don't pull more than its rated current, it should be fine.
#3 |
It works very well I will tell you. I have a 400 Watt Kicker amp for 2 10" Kicker Comp subs under my computer desk. It kicks good. A modern power supply will probably keep up excellently.
I can't wait until they decomision the pulverizer controllers at work. The circuitry runs off of two big 12 V 40 A power supplies. |
#4 |
Load either the 5V or 3.3V line so you are pulling maybe 100mA or so on it (a resistor with a small heatsink) and you should be fine. You may find that your 12V output is a bit lower than expected without the load on the 5V (or 3.3V) line.
Don't worry too much about pulling too much current- the PC power supply *should* shut down its output if it finds a fault, i.e. too much current draw). Power-cycling it should bring it back on. Cheers |
#5 |
Thanks for replying.
Happy Listening
| Are these caps safe? | Sonusthree | Power Supplies | 12 | 13th April 2007 01:01 PM |
| A safe (?) DC coupled amp | Fuling | Tubes / Valves | 4 | 8th July 2004 06:51 PM |
| Hakko 936 - ESD safe vs. non-ESD safe | KT | Parts | 2 | 20th June 2004 03:58 AM |
| Page generated in 0.07419 seconds (72.05% PHP - 27.95% MySQL) with 10 queries |
