Hi
Does anyone have a schematic for Rotel rb 850 Amplifier? |
#2 |
Hi Leisner,
PM me. I have a fragment that may help. It's not complete, and it's not great but it may help you out. -Chris |
#3 |
I have been researching the Rotel RB850 amplifier for several years.
I have compared it to the schematics of similar Rotel amplifiers. I saw a schematic on this forum that seems to have at least one error. It looked like a scan of a photocopy that had things erased. I have redrawn the schematic based on the one on this forum, similar ones found elsewhere, and my RB850. I will answer any questions you may have (as far as I know). There is a thread with this similar question on this forum Sincerely, Chris Browne Ground Noise Industries |
#4 |
This was posted by member "transducer" and marked in red
by "gni" |
#5 |
#6 |
Hi Gni,
What are the mods you did on this amp? I have a vector research integrated amplifier VA-100 with exactly the same power amplifier stage, and would like to tweak that amp. How does this amp sounds? and the tweaks improved the sound? Thanks, routhun
routhun |
#7 |
I emailed Rotel for the Technician Manual and they sent me one. . .it
has the Schematic and Bias Voltage (4mV across 0.22 ohms = 18.2mA) I replaced the single turn bias adjust pot with a 15 turn unit. . . |
#8 | |
Hi Chris,
You should install a new 270° unit at the very least, or put the old one back in after cleaning the slip ring and wiper. What you people fail to realize is that the multiturn types generally have a much smaller contact area and are not intended to pass DC current. I'm actually getting tired of hearing about this ill informed "upgrade". -Chris
"Just because you can, doesn't mean you should" © my Wife |
#9 |
Hi Chris,
The inability of multiturn pots to pass DC current explains why some of my projects won't work. Thanks for that, a great weight off my mind. Cheers, Steve.
The older I get, the more simplicity appeals. |
#10 |
Anatech??, a multiturn trimpot is nothing but a single turn with a screw and a cog to allow easier adjustment than a very cheap open frame single turn trimpot. Its the same thing, just imagine a single turn, sideways and enclosed in a pretty sealed case thats helps protect from dust and dirt buildup.
Colin |
| Service Manual/ schematic for Rotel ROTEL RHCD-10 Michi CD player | Staykov | Digital Source | 5 | 16th May 2012 12:24 AM |
| Rotel RB850 transformer blown? | rhiolly rub gt | Solid State | 5 | 16th April 2009 02:59 PM |
| Rotel RC-850 Pre Amp + Rotel RB-870BX | bleachershane | Analog Line Level | 4 | 9th February 2009 11:20 AM |
| Problem with Rotel RB850 | rmsmax | Solid State | 21 | 27th January 2009 12:42 AM |
| Rotel RB850 Still Current? Schematic Included | transducer | Solid State | 50 | 20th April 2008 12:36 AM |
| Page generated in 0.09771 seconds (77.13% PHP - 22.87% MySQL) with 11 queries |
