Old 29th August 2006, 03:55 AM   #1
dtm1962 is offline dtm1962  Canada
Default Replacing Emitter (metal plate cement type) with Mills WW non-ind.-Any Improvement?
Am I wasting my time in thinking there is any improvement if I replace the 2W low inductive metal plate cement resistor with a Mills non-inductive 5 W resistor for my emitter resistors in my Power Amp?
Has anyone tried this?
Any sound improvement or it is not critical enough to hear an improvement?
Any comments would be appreciated!
Thanks in advance,
Dan
Old 29th August 2006, 03:56 AM   #2
Default Should read "emitter resistor" in Title!
As stated in note of title.
Dan
Old 29th August 2006, 05:12 AM   #3
wrenchone's Avatar
Actually if the emtter resistors are really metal plate type, not wire wound, then the metal plate is cut in a serpentine pattern that's pretty non-inductive on its own.
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
Replacing electroytics in signal path with non-polarised - which type of caps to use? jpcoetzee Solid State 13 15th May 2008 01:12 PM
Metal oxide non inductive as emitter resistors in amp ostie01 Solid State 0 12th August 2006 08:10 PM
Aleph-type CCS as plate load? Fuling Tubes / Valves 18 22nd October 2004 02:46 AM
Page generated in 0.06194 seconds (67.31% PHP - 32.69% MySQL) with 10 queries
