Old 29th August 2006, 02:36 AM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Default BiMOS output stage
Have anyone ever build this kind of output stage,ie a MOSFET driving a BJT,similiar to an IGBT???
Old 29th August 2006, 08:43 AM   #2
djk is offline djk
djk's Avatar
A while back, Accuphase made a very large and expensive amplifier with lateral MOSFETs for drivers and bipolars for outputs.
Old 29th August 2006, 05:26 PM   #3
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Some Models of Inter-M amplifiers M-500, M-1000 used Lateral Fets as drivers and BJTs at outputs...
Old 29th August 2006, 05:31 PM   #4
ilimzn is offline ilimzn  Croatia
Also the rare Kyocera integrateds used this approach., They used the small (500mA) laterals from hitachi to drive two pairs of toshiba BJTs.
Old 10th September 2006, 10:01 PM   #5
darkfenriz's Avatar
ilimzn
Which particular parts do they use and which ones would you suggest? I would be looking for something like 150V/2A.
best regards
Adam
Old 10th September 2006, 10:33 PM   #6
2SK214, 2SJ77 were used to drive two pairs of 2SC3281, 2SA1302.
Certianly other combinations are possible. I used some myself in some experiments, they worked quite well. You may want to look at IRF710 and 9610...
Old 10th September 2006, 10:51 PM   #7
bikehorn's Avatar
how about this one?
http://ampslab.com/bi70mk2.htm
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 02:55 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
TV Horzontal Output Transistor for output stage..? ronybc Solid State 46 10th October 2005 02:26 AM
Page generated in 0.07711 seconds (75.47% PHP - 24.53% MySQL) with 10 queries
