Old 2nd October 2001, 06:50 PM   #1
Freddie is offline Freddie  Sweden
What is the easiest way to convert the gray-code output from a Bourns optical encoder to binary (parallell)?
I don't want to use a microcontroller. Perhaps there is a IC that converts from gray code to binary that I can use?
/Freddie
Old 2nd October 2001, 10:30 PM   #2
Jason Hubbard's Avatar
Lightbulb Translating to Binary
Perhaps using a simple prom/eprom device would suffice - feed the gray code output of the optical encoder (buffered to correct voltage if not 5v) onto the address pins of the prom, take the translated binary value (upto 8 bits) from the data pins.
Old 3rd October 2001, 11:12 AM   #3
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Default Gray to Binary
The classical way to convert Gray to Binary is as follows:
Feed the Gray MSB directly through to be your Binary MSB.
Then make an XOR of the the Gray MSB and 2.MSB. Output will be your Binay 2.MSB.
Then XOR this output with your Gray 3rd. MSB.
Output is now your 3. MSB Binary.
Proceed with XORing each output with your next following unused Gray bit until your all done.
That's all there is to it.
On the other hand, - generating a LUT in a PROM might do it in one chip, as 8 bits will need two XOR DIPs.
One DIP will suffice up to 7 Gray bits...........
Old 3rd October 2001, 05:18 PM   #4
Default thanks
AuroraB,
This was just what I was looking for. XOR ICs to convert from gray to binary, nice.
Thanks for the reply.
/Freddie
Tango series II binary PCB file help needed! Suoliang Everything Else 2 4th November 2008 04:51 AM
Problem witht [code]blah[/code] ? elseif Forum Problems 1 17th August 2008 01:30 AM
beautiful galaxy gray heatsinks kderedwolf Swap Meet 0 25th April 2005 03:36 AM
How to dye gray foam surrounds black? dhenryp Multi-Way 8 13th January 2005 09:55 PM
Page generated in 0.08406 seconds (71.12% PHP - 28.88% MySQL) with 10 queries
