the only part I got for the preamp is the 3 band tone controll
but they dont speak the same language with the poweramp I need a preamp that will increase the sound of microphone just a 1/4 phone jack mic Iam trying to build PA system |
#2 |
I know its not impressive
#3 |
you show 7.13v after R28. That is too low. Did you measure this voltage? The R10 to R15 ratio is very high. 47k:100 gives a gain of 471times (+53.5db)!!!
regards Andrew T. |
#4 |
seanmacss, your poweramp does not need a preamp to start to work, it needs a cleanup of mystery parts (r5 for example) and finally a real power supply. (using a +/gnd/- voltage) This floating supply does not look reliable. Reduce R10 to 27k (must be the same as r3) and increase r15 to at least 500ohm.
With the single 56v supply you will get at most ~30watts into 8ohm. How should the input diffamp work with +5.44v at +input and 6.24mv at -input ? sorry, Mike |
| SS Preamp and Tube Poweramp | Diogrus | Tubes / Valves | 0 | 10th November 2007 12:02 AM |
| what microphone preamp to use for poweramp??? | prorms | Solid State | 3 | 25th August 2006 11:52 PM |
| DIY preamp to poweramp cable question | Kuja | Solid State | 1 | 8th March 2006 06:18 AM |
| preamp with LM3886 poweramp | the3dmonkey | Chip Amps | 2 | 6th December 2005 11:57 PM |
| Split PREamp / Poweramp PSU for the Leach Amp | stigla | Solid State | 4 | 3rd February 2003 08:19 AM |
| Page generated in 0.07601 seconds (70.51% PHP - 29.49% MySQL) with 11 queries |
