Old 26th August 2006, 04:46 AM   #1
Default Does this amp look to be hard to fix?
I just received this amplifier that I purchased off this thread:
http://www.polkaudio.com/forums/showthread.php?t=42900
It came it near mint condition and 4 of the 5 channels are working. In the one picture (you need to scroll down the thread a little) you can see on the left where the resistor looks a little burnt. I was curious how hard it would be to fix something like this, and if someone like myself could do it? I have a friend with a $150 Weller soldering iron that has a ton of experience soldering active crossovers that could do the work for me. I haven't asked him for help yet, and was wanting to get a little bit of information here first.
Lastly, do you think I did ok for $160 shipped?
Thanks!
Old 26th August 2006, 07:36 AM   #2
clem_o is offline clem_o  Philippines
If the channel isn't producing any output, suspect the output transistors. It's easy enough to fix - IF you know which parts to replace. Finding out which ones (I am pretty sure it isn't only the resistor in question) is the one that takes skill, time and effort. I'd guess that your crossover expert friend would probably be able to do it...
Cheers
Old 26th August 2006, 02:00 PM   #3
TomWaits's Avatar
Default Not too difficult
That is a five channel amp and it seems four of the channels work perfectly fine. I may be wrong but theoretically it is an easy fix and you won't necessarily need a manual as you should be able to read and measure the component values from the good channels.
A few hours to assess and a few hours to fix.
Shawn.
Old 26th August 2006, 02:08 PM   #4
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
it looks more like the soot originated from the small mustard colored capacitor similar to the one in the middle of the pic.......
Old 26th August 2006, 03:59 PM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
The most important thing is know how to use a multimeter to measure the componets,esp semiconductors.
Old 30th August 2006, 09:55 AM   #6
Nrik is offline Nrik  Denmark
You definitely need to replace the emitterresistors, and the outputtransistors in both positive and negative section.
You might also need to replace the drivertransistors.
It is not enough just to replace those components that looks burned, because you can probably not see which ones of the transistors that are gone.
So if you have interest in electronics, and know how to solder, you can try to replace all the mentioned items carefully, and make sure that the new transistors have sufficient thermal contact with the heat sink.
If it allready sounds too scary then dont do a half attempt - send it to a dealer for proper service.
YES the amplifier is definitly worth it!!!
Old 30th August 2006, 05:12 PM   #7
I'm with DjQUAN, I think what looks like a monolithic ceramic cap (snubber cap) probably popped as well as the emitter resistors are also burnee out. The output transistors might still be functional but with burned out Re's then you would not have a connection to the load.
Best to have someone who knows something and check the transistors first to see if they are dead then go from there replacing what is blown.
-SL
Why is this so hard? Hirsute Zombie Subwoofers 8 13th February 2008 11:47 PM
How hard can it be? seth556 Chip Amps 32 10th November 2007 01:38 PM
FZ Broadway the hard way serosmaness Music 1 30th September 2004 10:30 PM
how hard is it to make a PCB? theChris Everything Else 0 3rd June 2003 08:40 AM
Page generated in 0.08875 seconds (78.34% PHP - 21.66% MySQL) with 10 queries
