Concerning using a servo integrator to greatly reduce DC offset for a basic power amplifier:
1) When the output signal is integrated and amplified (usually by an opamp integrator circuit), where is this feedback signal normally placed? I have seen designs that put the DC feedback signal at the inverting input of the input stage (just like where the AC regular feedback goes), and I have seen designs that put the DC feedback signal at the tail supply of the input stage (I think it adjusts the bias current such that the DC offset at the output is 0). Is there a guideline or rule of thumb to use? 2) Can the DC feedback signal be applied to the VAS stage instead of the input stage? Are there negative consequencese to this? |
#2 | |||
#3 |
If you are building a symmetrical dual differential design you may want to experiment with these two servo options: bias adjust and feedback voltage. My experience: the bias adjust sounds more dynamic; the feedback voltage gives a slightly better DC null and will compensate for a larger DC offset.
Any better suggestions for a symmetrical dual differential servo ? |
| Help with DC Servo for Current Feedback Opamp | klewis | Chip Amps | 31 | 4th June 2010 05:18 PM |
| How to determine the RC value of a DC servo(integrator)?? | Leolabs | Solid State | 1 | 25th October 2007 08:26 AM |
| Servo-feedback Subwoofer | dswiston | Digital Source | 25 | 26th October 2005 05:07 AM |
| Bandpass box with servo feedback??? | Circlomanen | Subwoofers | 0 | 16th August 2005 04:30 PM |
| Integrator in DC servo | Ipanema | Solid State | 5 | 17th May 2005 03:34 PM |
| Page generated in 0.08235 seconds (73.98% PHP - 26.02% MySQL) with 11 queries |
