Old 25th August 2006, 11:16 PM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default what microphone preamp to use for poweramp???
I cant decide or guess what microphone preamp to use with this poweramp the other problem is tone controls bass or treble
or bass mid treble and then a master volume and and a volume
ineed a schematic !!!!!!!!
I just cant find one
here is the power amp iam using
Old 25th August 2006, 11:17 PM   #2
Default the part list
parts use
Old 25th August 2006, 11:36 PM   #3
Speedskater's Avatar
What model or type of microphone will you be using?
What will you use the system for?
How high of audio quality do you need?
Kevin
Old 25th August 2006, 11:52 PM   #4
Default microphone specs
Dual-impedance microphone, 600 Ohm and 50K 1kHz. Unidirectional cardioid pattern. Black diecast construction Detachable, 15' low-loss cable with 1/4" phone plug and XLR connector. Sensitivity: 73dB plus or minus 3dB @ 1kHz. Frequency response: 100-13kHz
SS Preamp and Tube Poweramp Diogrus Tubes / Valves 0 10th November 2007 12:02 AM
poweramp need a preamp?help urgent pa system prorms Solid State 3 27th August 2006 11:57 AM
preamp with LM3886 poweramp the3dmonkey Chip Amps 2 6th December 2005 11:57 PM
passive preamp for quadII poweramp renjiish Tubes / Valves 10 16th October 2003 12:15 AM
Split PREamp / Poweramp PSU for the Leach Amp stigla Solid State 4 3rd February 2003 08:19 AM
Page generated in 0.07342 seconds (75.19% PHP - 24.81% MySQL) with 11 queries
