Janneman
Sound engineers have been learning that CD needs different mastering than LP.
But, Jan, do not underestimate digital residuals and jitter, very different from wow and flutter in human perception.
LP has a lot of shortcomings, which are probably not that irritating as signal correlated noises, jitters, phase modulations and other digital shortcomings.
Come on, guys, get real. Most LPs these days are not directly mastered from the output of some analog mixing console and analog sources. They are in fact mixed from a digital source, usually one with a slightly higher bit and sampling rate than 16/44.1.
So what that means is that the signal on the LP also went through a DAC at some point (and coming to think about it, an ADC is also just a DAC and a comparator). If you distrust DACs and digital playback, you might also scrap most CDs these days.
And chocoholic, do me a favor and read a text on signal theory. You remind me of this guy who travelled around German university town and put up one-man marches against quantum physics. His point was that matter just couldn't be 99.9% hollow and hence quantum physics had to be mistaken...
AX tech editor
Joined 2002
[snip]
So, OK, if that is the case, is the (sometimes) big audible difference between CD and LP just a matter of the badness of jitter and the "niceness" of clicks and pops? I find that hard to swallow.
Jan Didden
We surely know.
I have a lot of LPs, starting from some 1960 (Columbia, Verve Decca), through early digital PCM era till nowadays. And you can tell the difference. Guess what is worst .... ;)
I do not prefer LPs for classical music, as they lack from recordable dynamic range. In fact I do not prefer LPs, But I understand some advantages they have for human perception.
And - CDs are about correct (proper) replay, which is not easy at all!! (So our experiences may differ a lot).
Even in several last years there are excellent converters (digital filters) and players. It is more difficult to get "enough" from CD than from SACD and DVD-A.
And good mastering is of course needed (Bob Ludwig).
I am not sure and I am only guessing ;) (as almost everyone).
Anyway, aliases must be avoided by steep anti-aliasing filter, both on A/D and D/A side. A/D side is, as known, 64 x 44.1 sigma-delta. Then decimation to 44.1, so filters are digital for both at A/D and D/A converters, with analog filter at the output behind D/A.
Digital filters, their algorithms and spectral purity (background) are surely one of the cases.
lumanauw said:
When Sony/Philips set the standard of audio CD of PCM, 2channel, 44.1khz, 16bit, they must have covered all that can be "heard" between 20hz-20khz. So, what do they miss?
Could it be that the one that makes LP sounds different than CD is actually noise+distortion?
Live musical instruments have quite high spectral content up to 40kHz (look at my SACD and LP spectral files). Ultrasound signals probably intermodulate on ear non-linearity, producing audible frequencies. You cannot hear ultrasound frequencies alone, but you can probably hear their intermodulation products with "audio range" frequencies.
P.S.: But I do not think that this is the only reason that makes a difference.
umm does that mean LP is as good as CD?
umm i dont know, the specs of CD still look
better.
john
Hi David,
Maybe not -
There was at least one company that thought 16/44 wasn't good enough, (Decca?), they wanted it up'd to 20/44 at least. I think, just like any technology, there are tradeoffs that are considered and in this case playback time was the issue (they wanted to fit a symphony into one disk, don't remember which particular symphony and it happened to be ~70 minutes long).
Also, why would Sony et al introduce SACD (well, ok, aside from reducing bootlegging)?
The kinds of distortions / problems between LP and CD are very different (i.e analog distortions versus digital), and perhaps the bottom line is, the 'problems' with CD are just more annoying to the human ear.
Cheers!
Clem
What matters is that the signal recorded into CDs is not the same signal as the one recorded into LPs. Furthermore, CDs usually contain a different mix with different EQ, done at a different time and with heavy compression (to make it very loud -and harsh- within the available dynamic range). That's like comparing apples to oranges.
In order for any valid comparison to take place, both discs have to be recorded from exactly the same signal (which is usually achieved by doing it at the same time and in the same place, something very unlikely to happen).
Eva IMHO has a valid point.
I recently spent some time reading digitised LPs and various CD issues of the same album into a DAW and it is obvious that versions are mastered to entirely different standards. Even 'identical' CDs show differences, the question not being whether recent editions are slammed into 0dBFS but rather *how much* of the signal is clipped.
In some cases this was obviously done as part of the on-going loudness race. In other cases I wonder whether it simply was not the well-intended but ill-guided attempt of the mastering engineer to 'optimise' the medium's dynamic range by clipping off 'just a tiny handful' of peaks (*), throwing out the natural flow and dynamics of the music in this process.
Doing so is very tempting when you are sitting at a DAW. It is also something that was entirely impossible in the pre-DAW days, and thus something that was never done on LP.
I asked this question to Mr. Bruno Putzeys.
This is the answer :
There are two important factors at play.
1) Problems with digital gear. Most digital audio gear, especially CD players, are badly designed. To obtain optimal quality in a digital audio system, there are several very important issues to take care of:
*Nyquist Criterion. It says all frequencies equal to or higher than Fs/2 must be blocked. Most ADCs and DACs block only frequencies >0.55fs. So there is still a region between 0.45fs and 0.55fs (for CD: 20kHz to 24.1kHz) that has aliasing components.
*Pre-Echo. The most economical digital filters have a constant "in-band ripple". These filters are called "equiripple". This translates to an echo before and after the "pulse". It is much better to use a "windowed sinc" filter. However, for the same stop band specs, a windowed filter is about 50% longer, so it takes more processing capacity.
*Clock stability. The sampling clock must be very stable and any phase noise (jitter) must be random. Unfortunately, many CD players have a clock oscillator operating from the same supply as the CD drive. All servo action and digital processing cross-talks into the clock. This is why most CD players sound different when you play copied CD's. When a CD player is correctly designed, a copied CD sounds the same as the original, and
mechanical stabilisation has no effect. Refer to posts by Guido Tent (another ex-philips guy) for more information.
2) Distortion in vinyl playback. Distortion of LP recordings is 0.1% and higher. Distortion becomes worse at high frequencies. This can give the impression that LP's have more "punch". Except when the distortion is very bad, it is usually perceived as "pleasant".
When you listen to a digital chain (even only 44.1kHz/16bit) that is 100% correctly executed, it will sound vastly better than LP. No question about it. If you go to 96kHz/24bit, you can make a digital chain that is totally transparent (so you cannot hear the difference between the ADC input and the
DAC output). Some people will still prefer LP, but then clearly it is
because they like the extra distortion. These people will prefer the sound of the LP over the signal that comes directly from the studio.
Re anti-aliasing filters:
there are several options at the CD mastering stage that can be used to alleviate the problems with crappy ADC chips (in studio gear, yes!) and with crappy CD player implementations. All of these solutions trade something for something.
Absence of the discrete pre/post echo (see Lagadec) requires filters with a monotonic frequency response.
A shorter total filter impulse response (for the time-smear freaks) requires filter with a wider transition band. One could sacrifice passband for this. I have designed filters that are ruler flat out to 15kHz, then roll off to -140dB at 20kHz or 22kHz. -3dB is at around 18 or 19kHz. Impulse width is 400-500us, as opposed to the 1000us generally encountered for CD audio.
The treble loss is IMO insignificant. But then I can't hear above 15kHz anymore :D
One could do similar with a transition band from 15kHz to ... 24kHz or even higher. Yes, this allows a limited amount of aliasing. But the aliasing components all fall in the very top range of the treble band, while the ear cannot discern discrete pitch above ~12kHz. So the perception of the aliasing is only a slight brightening of the treble as a whole. dCS do this. The result can be an even shorter impulse width.
This is all a far cry from equiripple half-band filters, but still trivial on a powerful PC with Matlab or Octave.
These techniques are slowly being adopted in top-end pro ADCs (only those where the AA filtering is entirely in the hands of the manufacturer of the instrument, as opposed as carved in silicon) and in Digital Audio Workstation software and plug-ins.
I have read some interesting threads on some Pro Recording Engineering forums.
While I tend to agree a good analogue source will always slaughter a good CD source, a good CD source can be a hit and miss affair as its so full of false assumptions and misinformations.
Most engineers will monitor a modern recording following A/D and then back via D/A conversions, often via headpones or near field monitors. It is reasonable to assume that they, having seen and hear the original acoustic performances know what is right and wrong from the original.
Really good converters have never been afordable to consumers so they master the end product to delivery a desired result on the basis of what consumers are likely to be playing it back on.
However, impressive and affordable D/As are recently are now available like the Lavry DA10, the Altmann Attraction dac.
clem_o said:
Hi David,
Maybe not -
Cheers!
Clem
IMHO:
...when Philips and Sony settled the standard of 16bit/44kHz, they settled it to a level, which they rated as good enough to satisfy 80% of possible customers. And they where perfectly right. CD wiped out LP almost overnight, because it is so practical and good enough for most people. And as they have an excellent marketing, they won the race even in sound comparison, because if you compare cheap systems, most often the cheap CD players sound more acceptable than an old scratchy LP on a poor player. These guys know exactly what they are doing.
Business in large scale, not just making happy some freaks like us.
Just the other week, I was talking with James Lock about some of the subjects being discussed here...
He said that in the beginning of the digital era, many digitalisations of old material was careless, and because of that, the same work on LP or cd sounds totally different, because at that time, it was pertinent to have more and more titles available to the public.
Some of the discs you buy now at the stores are the same careless jobs done earlier.
Adding to that, the degradation of master tapes dictates that some of those fantastic recordings are lost forever.
That’s what I call the perfect sound forever…
This append on a quality driven company like Decca. Now think of what happen at regular recording companies.
So just because it is the same performance on CD and LP don’t expect the same quality, and I have to agree with some post made on this thread. Mastering dictates almost everything.
Lock was very vehement in bashing accountants for destroying the audio industry, and unfortunately I have to agree with him… Only money counts theses days.
A personal remark is that, my cd player blows away any turntable a ever heard (and I have heard some pretty expensive ones), even my won LP setup, on a good recording, but I have to admit that many recording just sound better on LP.
To those who don’t know James:
http://www.google.pt/search?hl=pt-PT&q=james+lock+decca&meta=
rick
