Old 22nd August 2006, 02:10 PM   #1
sparkle's Avatar
Question what is the highest temperature for the BJT's to operate safelly
I have MJ15003's and they operate arround 32W and the heatsink is bad for them (not good enough).....What is the maximum temperature on which those transistor can operate not to become damaged during time......??!!
Has anyone tried to operate them (long term) on 70 degrees Celsius)?! The amp is JLH class A, single ended......
Old 22nd August 2006, 02:22 PM   #2
pinkmouse's Avatar
The principle is simple, the hotter the device, the shorter the life. If your heatsinks are running at 70 degrees, I feel that that is too hot. Get bigger heatsinks, or a fan.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 22nd August 2006, 02:32 PM   #3
BobEllis's Avatar
From the data sheet:
Rjc = .7 C/W
Junction temp max = 200C
So add ~1.2 C/W for the isolator if using Mica/grease and your junction is 1.9C/W above the heat sink temperature. Your Junctions are ~61 C above heat sink temperature or 131C.
Nelson Pass recommends 100C max for reliability using IRF devices with a max junction temp of 150C. Scaling that to your 200C max, you are probably OK, but as PM said cooler is better. Not to mention the danger of burning yourself or your guests on the 70C heatsinks.
Old 22nd August 2006, 02:40 PM   #4
sparkle's Avatar
no,no, no - heatsink is not 70 Celsius - but the top cover of the MJ15003 - the "hat" that covers the chip inside - the "L" profile where i have attached the transistors is arround 60 Celsius .....
this seems to me to be at the edge but still o.k. - agreed ??
thnx for the answers
Old 22nd August 2006, 02:50 PM   #5
BobEllis's Avatar
so, if your case temperature is 70 C, then your junction is .7xPd greater, or ~92C. Shouldn't be a problem at all. not even on the edge
Old 22nd August 2006, 02:51 PM   #6
poobah is offline poobah  United States
poobah's Avatar
You're OK... just barely. Like Pinkmouse, Bob, & Nelson... cooler would be better. U.S. military says 110 C on all junctions... max. Lifetime goes in half for every 11 C increase in operating temp.
Old 22nd August 2006, 02:58 PM   #7
sparkle's Avatar
o.k. thnx guys......
barelly allive
Old 22nd August 2006, 05:06 PM   #8
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Do you have any links to any thermal derating documentation rearding lifetime in semiconductors?
\Jens
Old 22nd August 2006, 05:13 PM   #9
Hi Jens,
that's a good question.
Now you have me wondering if all the previous estimates of lifetimes that I have seen, have been "old wives' tales" or based on factual evidence.
regards Andrew T.
Old 22nd August 2006, 05:28 PM   #10
The one and only
Nelson Pass's Avatar
Keep in mind that temperature has a dramatic influence on the
second breakdown of bipolars, so the 70 deg figure is very
safe at lower voltages, but when you get above 50V or so,
it gets more dicey.
CDP-X3000ES operate without digital filter ? Bernhard Digital Source 0 4th September 2007 04:26 PM
Will the tda1543 operate statically? pixpop Digital Source 4 12th August 2006 10:24 PM
Any power stage could operate upto 6MHz? are there?? banana Class D 47 13th July 2006 04:52 PM
Is it possible for Aleph to operate in class a/b or b mode? audionut Pass Labs 1 8th March 2006 06:07 PM
Page generated in 0.08604 seconds (85.39% PHP - 14.61% MySQL) with 11 queries
