Old 22nd August 2006, 01:57 PM   #1
Default Loudspeaker protection
Im putting together a stereo amplifier and just wondering if anyone knows of a good loudspeaker protection module I can use? I notice jaycar/altronics have, does anyone design there own?
Old 23rd August 2006, 01:50 AM   #2
HI Nick:
Try using either NEC UPC-1237H, or Toshiba TA-7317P.
regards,
Art
Old 23rd August 2006, 02:47 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
http://sound.westhost.com
Old 23rd August 2006, 09:10 AM   #4
How about this :
http://users.otenet.gr/~athsam/protection_2_EN.htm
But this is for a 60v DC supply and I had the modified bom for a 33v DC (ie 24v AC before rectification).
Old 23rd August 2006, 04:31 PM   #5
Default Protection circuit
A very valid circuit,more reliable than the TA7317 or uPC1237 and easy to built is this(with blinking LED).
The description are very simple:when a DC voltage are detected,the output of X1 are low or high depending to DC voltage.When a positive offset voltage occour,the X2 output quite low and D1 short the gate of M1 to approx negative supply.This cause relay to open.Similarly for the negative offset(same but for X3).
The initial turn on delay may be set with R7-R12/C3 and the LED blinking time varying R14/C8.
The off response of this circuit are very fast(depending on the relay characteristic).
Old 23rd August 2006, 04:32 PM   #6
Default THE CIRCUIT
the schematic in pdf format.Any comment are very appreciated.
loudspeaker protection relays? h_a Parts 8 4th September 2008 07:43 AM
Loudspeaker protection... Skorpio Solid State 12 23rd January 2007 01:10 PM
Loudspeaker protection kit Vivek Multi-Way 98 5th September 2003 07:49 AM
Page generated in 0.07142 seconds (74.79% PHP - 25.21% MySQL) with 11 queries
