Old 21st August 2006, 12:41 PM   #1
Skorpio is offline Skorpio  Denmark
Default Rotel RA-840BX4
I am looking for schematic for this amplifier.....
Old 21st August 2006, 01:33 PM   #2
Lenin is offline Lenin  United Kingdom
Smile Any 800-900 series schematic will do...
Contact Rotel direct, they have always supplied me with schematics - at a cost of £5.
I doubt that policy would have changed.
The amplifier you mention (along with all Rotel amps in the 800 - 900 series) are derivative of a design Stan Curtis did for Rotel.
(I suspect later amps are derivative too).
If I can find my schematics (all now in storage following a move) I'l scan and post here.
Lenin
Old 21st August 2006, 04:27 PM   #3
Thank you for a fine answer.....Stan Curtis has also made a Class A in the 80'ties?
Old 22nd August 2006, 08:10 AM   #4
Looking inside the amp, I found some interesting things:
-No output series inductor/resistor
-No zobel network at output (cap and resistor from output to ground)
-Fuse in series with output (4A)
-Very hot driver stage, looking like an single ended emitter follower, with 1K resistor as load..(one for each half)...
Old 8th January 2009, 09:49 AM   #5
Hi Scorpio,
If you are still looking for the schematics I can send you the scans.
I started this week my own modding project for this great amp. As of today I am quite pleased with the first result. I would be happy to find some one in the forum who likes to share some thoughts or experiences of Rotel 840 BX4.
I will come up with more information soon.
Best
Joerg
Old 8th January 2009, 12:50 PM   #6
Default SM Rotel RA-840BX4
you can download it for free from:
3w.sendspace.com/file/6k4i2y
Michael
Old 8th January 2009, 03:05 PM   #7
Pingrs is offline Pingrs  United Kingdom
Michael,
Useful post. Now I can start resurrecting one I've been given.... or is it worth it? Is it a "great amp" or should I rip out the guts and use the case etc. and fit something "better", e.g. Leach, Symasym, FC-100 or DX's?
On second thoughts, maybe I should fix it then listen.
Thanks,
Brian.
Old 10th January 2009, 11:05 PM   #8
Default Rotel
for my opinion Rotels are always very good, soft sounding Amps.
Old 11th January 2009, 12:34 AM   #9
homemodder's Avatar
Had a look at the schematics, its definetly worth to fix, very nice amp and very decent design. Just change the usual, old caps, upgrade the opamps, I would upgrade some transistors too, would be a fine amp.
Old 11th January 2009, 10:14 PM   #10
There is a lot to improve ;o)
What I did already:
-Killed/bridged the sound tuning (bass /treble) section
-Removed the rubbish multi switches
-Replaced the cheap volume potentiometer by a new one from ALPS
-Changed the speaker wiring (removed remote speaker connectors) and removed the headphone wiring.
-Replaced the NE5532AN with an PMI OPAMP. Maybe will test BurrBrown ones.
What I still want to do:
-Add new high quality cinch adapters
-Restructure/Improve the wiring from cinch->volume->preamp->amp
-Add new speaker connectors
Still not sure if it is worth to replace some electrolytic capacitor or to bridge the big ones with films.
Second I don't like the fuses in the amp speaker output. Any suggestions ?
Cheers
Joerg
Service Manual/ schematic for Rotel ROTEL RHCD-10 Michi CD player Staykov Digital Source 5 16th May 2012 12:24 AM
rotel ra 820 diymax62 Solid State 1 11th May 2009 12:05 PM
Rotel RA 931 argonrepublic Chip Amps 0 20th April 2009 01:26 AM
Rotel RC-850 Pre Amp + Rotel RB-870BX bleachershane Analog Line Level 4 9th February 2009 11:20 AM
Rotel 955 CDP Craig S Digital Source 0 10th February 2005 12:43 PM
Page generated in 0.09732 seconds (78.83% PHP - 21.17% MySQL) with 10 queries
