Old 21st August 2006, 12:05 AM   #1
dtm1962 is offline dtm1962  Canada
Default Blackgates - Std. vs NX-HiQ as coupling applications
My Rotel Pre-Power & CD Players has a total of 5 std 47uF Blackgates per channel (in signal path) in the coupling function to address DC offset.
Is there any advantage to switch to 47uF 6.3V NX-Hi-Q in terms of sound quality improvements?
Film Caps are too bulky and create other problems (i.e inductance in leads/noise pickup etc)
Any comments or experience would be appreciated.
Dan
Old 21st August 2006, 04:04 PM   #2
Default Anyone directly compare these?
Anyone have any experience with this comparison?
I searched and could not find this direct comparison.
Any comments will help me decide if I want to buy these NX-Hi-Q caps.
Dan
Old 22nd August 2006, 02:48 PM   #3
Dan,
I can recommend the change. To me it was better than a standard MKP, SOLEN, cap. But before changing, check whether you need one at all! Look for dc offset on the caps. If it's below 30 mV, don't use a cap.
Just be aware that the Hi-Q is only rated for 6,3 volts. For a cd-player it won't be a problem but for a pre-amp, the 6,3 volt will be a little low.
Just try it on your player, the price isn't that high, a few $ a piece. Look for www.partsconnexion.com.
Good luck
Rob
What is the substitute for blackgates? AJ Bertelson Parts 1 25th March 2009 03:40 PM
Blackgates losing air adfairless Parts 10 16th June 2007 01:08 PM
Cerafine VS Blackgates? Htguy Digital Source 5 24th January 2006 10:10 PM
Where can I buy Blackgates??? K-amps Parts 3 25th February 2005 01:07 AM
Do Blackgates age? ainami Parts 4 10th January 2005 10:34 AM
Page generated in 0.07829 seconds (69.77% PHP - 30.23% MySQL) with 10 queries
