Old 19th August 2006, 03:23 PM   #1
Default Linearizing diodes in amp circuits.
Greetings.
Are linearizing diodes ever used to linearize the transfer characteristic of transistors in audio amps? I haven't seen any examples in the schematics. Google indicates that the technique is used in RF amps and diode lasers, but no examples in audio amps that I can find. Is there any role for them? what are the difficulties in using the technique? Are there any casualties among you from attempts to make it work? I look forward to your views with interest.
Old 19th August 2006, 04:29 PM   #2
diyAudio Moderator Emeritus
Where to put diode in the transistor? You got example drawing?
Old 19th August 2006, 04:59 PM   #3
Take a look at this:
http://ca.search.yahoo.com/search?p=...-web-t912&b=11
Go to number 12.
Old 19th August 2006, 05:45 PM   #4
It is LM13600
Is the linearizing diode is D2 and D3? What are they doing there? What's the mechanism to obtain the "linearizing"? Won't the DC offset annoyed?
Old 19th August 2006, 06:21 PM   #5
I haven't sketched any examples yet. I will study the examples referenced in the reply from member lumanauw before spending time on it. I am putting off working on this idea in case there are some compelling reasons to avoid it.
Old 19th August 2006, 06:32 PM   #6
>http://ca.search.yahoo.com/search?p...b-web-t912&b=11
>Go to number 12.
There is plenty of material to study there. I am still curious why there are no examples of discrete amps using linearizing diodes.
I expect it is easier use them in ICs due to better matching of diode and transistor properties when they are on the same die.
Old 19th August 2006, 06:37 PM   #7
I expect I would use them to linearize the input transistors which give voltage gain. Small signal transistors; FETs and tubes all seem to have a non linear transfer characteristic and so there might be a role for linearizing diodes. This would be an alternative to high open loop gain with feedback to achieve linearity.
Old 19th August 2006, 06:53 PM   #8
darkfenriz's Avatar
You can "linearize" current driven common emitter stage to current mirror. You will get lower gain, but better linearity. Good basic example?
Old 19th August 2006, 10:51 PM   #9
Very hard to do right, except by experts.
Old 19th August 2006, 11:00 PM   #10
latala is offline latala  United Kingdom
The first think that comes to my mind is the baxendall diode as used inthe Linsey Hood 75 watt design ! This is used to match the transfer characteristics between the quasi-complimentary output stage transistors !
A similar technique is also used in the old Phase linear 400/700 power amps
Regards Trev
Idea for linearizing a cascoded VAS ionomolo Solid State 9 27th June 2008 08:44 PM
Connecting Virtual Ground Circuits with True Ground circuits?? Minion Solid State 1 12th February 2007 01:28 AM
protection diodes in LM317 circuits jarthel Parts 2 14th September 2006 10:28 PM
Research on tubes and circuits simple circuits Cazcotty Tubes / Valves 6 16th June 2006 12:50 PM
85 powersupply circuits 58 charge circuits gev Power Supplies 0 31st July 2005 11:27 AM
Page generated in 0.09643 seconds (78.94% PHP - 21.06% MySQL) with 11 queries
