Old 17th August 2006, 04:28 AM   #1
sol is offline sol  United States
sol's Avatar
Default Question about active filter noise
So my first attempt at making an active filter has not gone so well. The filter is generating tons of noise. I'm looking for some advice.
So far filter has two stages: an input buffer and baffle step compensation. Goal is to grow to be a 24 db Linkwitz-Riley subwoofer XO with baffle step for the high out and additional EQ on the low out.
When I connect the circuit, I get terrible noise and distortion. Noise is even present when there is no input: my two stage filter is a white noise generator.
Strange thing is each stage works fine by itself. Running signal through either stage is fine.
I'm using NE5532 opamps, 1% resistors, and Panasonic poly caps. Input is an iPod, for now. All together on a solderless breadboard. +-12v supply.
I based the design ideas on John Pomann's active filter kit site, as well as info from Eliot Sound projects, and other info I found from threads around here.
This must be something very simple that I'm missing. Any ideas?
Old 17th August 2006, 05:45 AM   #2
clem_o is offline clem_o  Philippines
It might be oscillating. Solderless breadboards won't really give you the signal layout / grouding / good connections that you want for a high-gain opamp application.
Have you checked your power supply as well? Are the power lines properly decoupled? Have you checked your grounding scheme?
Cheers
Old 17th August 2006, 05:59 AM   #3
I second that and I'd like to add that you'd have to pay special attention to 78xx and 79xx voltage regulator ICs if you use such.
Charles
Noise out of active notch filter reins Multi-Way 0 6th July 2006 07:34 PM
Active filter question youyoung21147 Parts 3 21st May 2006 05:27 PM
active filter question jimbo1968 Multi-Way 3 6th February 2006 08:36 PM
Noob question : what exactly is the "Q" of an active filter ? youyoung21147 Chip Amps 7 10th December 2005 09:39 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
Page generated in 0.07587 seconds (72.22% PHP - 27.78% MySQL) with 11 queries
