Old 17th August 2006, 12:48 AM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default lm380 2watt amp
have trouble at the point were the treble bass section meets
the lm380 singal does come out be its very low
Old 17th August 2006, 01:59 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Why no output coupling cap???
Old 17th August 2006, 02:06 AM   #3
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Smile lm380 2watt amp
Just a guess.There seem to be missing junctions/black dots or connectors.See R6,11,12 and 8. C1 and also negative input of opa134.Output to lm380? Good luck.
Old 17th August 2006, 02:58 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi seanmacss,
Tell me that your +10V is not connected to the inverting input of the op amp driving the LM380. The output also has an AC short to the positive supply through C1 (goes to ground and +10V, right?).
I haven't seen a tone control with C6 and C8 in those positions, try removing them.
Absolutely! Not unless you need to bias that input to 1/2 Vcc from an external source, then what you are doing is fine.
-Chris
lm380 question jufreese Chip Amps 14 15th March 2008 08:16 PM
2 watt lm380 amp prorms Chip Amps 0 17th August 2006 12:47 AM
Looking for NEC 575C2 2Watt Chip Franz G Chip Amps 5 5th July 2005 03:48 PM
WTB 4 x 2watt 1k8 in UK penance Swap Meet 0 16th June 2004 11:26 AM
Page generated in 0.06854 seconds (72.99% PHP - 27.01% MySQL) with 11 queries
