Old 16th August 2006, 01:56 AM   #1
tumler is offline tumler  Australia
Default Inductors
Hey,
I'm about to start building my first amplifier but I have been caught on what the inductor(choke) is?
I'm building the Jaycar Studio Series 350 amp and need a 6.8uH inductance.
Would somebody be able to give me a link or tell me how to make one.
And the only inductor / choke I can find in Jaycar with 6.8uH is a RF choke, I'm sure this won't work but could somebody please tell me the difference between a choke and inductor.
Thanks alot
Old 16th August 2006, 02:04 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Try to search on Wikipedia.
Old 16th August 2006, 02:26 AM   #3
rpapps is offline rpapps  Antarctica
Hi Tumler
The instructions for making it are in the Silicon Chip article, February 2004, page 23.
If you can't get hold of it, it's 23.5 turns of 1mm enamelled copper wire wound on a 13mm inside diameter plastic bobbin.
Wrap in insulating tape to hold winding in place.
Incidentally, depending on where you got the circuit from, there may be an error. Check the 470uF cap on the -70 rail adjacent to F2. The original schematic has this reversed and could be an explosion risk.
You should also check the notes & errata here:
http://www.siliconchip.com.au/cms/A_104440/article.html
Cheers
Rob
Old 16th August 2006, 06:21 AM   #4
Thanks alot Rob
more than enough information to get me started
Old 16th August 2006, 06:31 AM   #5
Hi
You're welcome.
If you can't easily get the 13 mm bobbin, 1/2 inch or 12 mm dowel rod would probably be fine. Just make it 24 turns.
Cheers
Rob
diy inductors speedie Parts 23 21st October 2009 12:02 AM
inductors tonysherwin Multi-Way 3 7th May 2008 10:00 PM
Inductors in T Amp @lf Class D 55 21st November 2005 10:16 PM
A little help with inductors Kram Parts 2 8th February 2004 07:04 PM
Anyone tried these inductors? blank527 Pass Labs 9 9th January 2003 02:16 PM
Page generated in 0.07995 seconds (73.17% PHP - 26.83% MySQL) with 10 queries
