ok this should be an easy one
just hooked up a Quad 33 +405 and there is something crossed the left and right channels are swapped and the balance is only centered when the control is all the way to the left, which turns down the left speaker. I am guessing there is a pot controling the balance that is shot or was improperly repaired anyone have an answer? |
#2 |
see to that only the "stereo" button is pressed...
#3 |
and when i press the left mono btn it turns off the left
right turns off right and yes the speakers are hooked up correctly unless of course the brits have there lefts and rights backwards with stereos like they do driving i was thinking before that i was possible that the wires were crossed in the din from the pre to power but that doesn't explain why the balance control has to be all the way left to turn down the left speaker to match the right |
#4 |
Did it Himself
I suspect the balance pot is either shot or has been replaced with a logarithmic one by a monkey.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
I took the 33 to work today along with the 4pin output din so i could make use of the nice meter and iron there.
and yes it had been worked on by monkeys. the L and R lines had been swapped on one end of the output cable as i first thought and the pot for the balance was not centered. It went .25-1.25 on the left and 0.0 to 1 on the right. This made me rather happy as it was a 10 min fix with no cost instead of the start of a search for new pot or worse. I was absolutly amazed at how clean it was after opening it for the first time. Not a speck of dust inside, looked like it was new. For something thats as old as I am i was very impressed as most electronics today look like crap after about 6 months. |
| PP bias balance pot | fred76 | Tubes / Valves | 1 | 29th November 2007 06:34 AM |
| What is true balance? | Aaron323 | Solid State | 8 | 5th January 2006 07:38 AM |
| Balance Pot, (=retro?) | Cobra2 | Everything Else | 2 | 1st December 2003 09:25 AM |
| Are Balance Controls Still Necessary? | runeight | Tubes / Valves | 32 | 2nd November 2003 10:47 PM |
| Balance control | 2Bak | Pass Labs | 4 | 11th July 2002 07:07 AM |
