SOA Protection by Relay. - Page 5 - diyAudio
Old 18th August 2006, 03:22 PM   #41
anatech is offline anatech  Canada
anatech's Avatar
Hi Mike,
They are on VDE/UL/CSA certification. I would help if they used their heads once in a while though. Mind you, many times the safety organisations can be fairly stupid too and force these "gifts" on us.
If these parts go open (and they will in a fault), it will guarantee excessive current in the output stages. Like tons of uncontrolled current. There would be high current in a failure, but not like this unless an output shorted.
They will probably not discolour and confound a technician without experience, or the poor guy without a diagram (thanks by the way!).
-Chris
Old 18th August 2006, 10:46 PM   #42
The one and only
Nelson Pass's Avatar
Default Re: Re: Examples:
Originally posted by mikeks
Sony TAN-R1:
http://www.thevintageknob.org/SONY/s...NR1/TANR1.html
Odd that Sony refers to this as SEPP Class A, but looking at the
schematic I don't see it, I only see complementary followers.
Old 19th August 2006, 12:25 AM   #43
mikeks is offline mikeks  United Kingdom
Account Disabled
SEPP=Single Ended Push-pull
Old 23rd August 2006, 12:58 AM   #44
Account Disabled
see patent
The circuits in this patent cannot work as advertised, in any case, as the relay will simply chatter on and off-if at all.
A latch is mandatory.
Old 27th August 2006, 01:09 AM   #45
Account Disabled
Thumbs down It gets worse...
Sony's last so-called ''current feedback'' ''high-end'' offering uses a crude shortcircuit-only arrangement, which is supposed to VERY prematurely limit each of five pairs/channel of 2SK1530/2SJ201 MOSFETs to just 6.7A regardless of Vds (but doesn't in practice because of the relay's drop-out time-constant), leaving the MOSFETs unprotected for Vds>20V and Id<=6.7A.
Abominable!
Old 27th August 2006, 11:34 AM   #46
Account Disabled
Exclamation In fact...
...the power output of this amp could be readily and usefully increased, from its alleged four ohm capacity, to accomodate one ohm loads, at least on a transient basis, while simultaneously providing foolproof SOA protection for its output stage.
Old 27th August 2006, 04:46 PM   #47
anatech's Avatar
Hi Mike,
What a dum arrangement!
-Chris
Old 27th August 2006, 07:33 PM   #48
Account Disabled
Originally posted by anatech
Hi Mike,
-Chris
..and for $14000 to boot..
Old 27th August 2006, 08:04 PM   #49
anatech's Avatar
Not from my wallet! But it is shiny ...
NAD 214 protection relay Bennyboyph Solid State 5 29th May 2011 08:48 PM
Loadspeakers relay protection shmuelb5 Multi-Way 3 30th August 2005 09:03 PM
DC protection relay flashes djdamix Solid State 8 16th June 2005 02:19 AM
Copyright 1999-2017 diyAudio
