Old 14th August 2006, 02:16 AM   #1
ostie01 is offline ostie01  Canada
Default Is this transformer good for power amplifier
Hi, would like to buy this toroidal transformer on ebay and would like to know if they are good choice for a power amplifier project.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
Old 14th August 2006, 03:43 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Yes if you are building amp with 46V rails.At this voltage looks like it going to be over 100watts.But at 1000kva it's overkill and huge.Check whether is suitable for your country's AC line.
Old 14th August 2006, 03:58 AM   #3
infinia is offline infinia  United States
infinia's Avatar
Hi
May be OK if using bridged into 2-4 ohms but overkill otherwise. Probably need higher voltages to get higher power into 8 ohms. Search for an amplifier firstly, then look to design the powersupply given your drive/load requirements. Another thing to watch out for is non-vacuum impregnated xfrmers can be audibly noisy.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 14th August 2006, 04:27 AM   #4
Hi, I don't know why 46Vac which give 65Vdc on the rails would not be powerfull enough, I think this is about at least 200w of power.
Old 14th August 2006, 07:21 AM   #5
djk is offline djk
djk's Avatar
That transformer would give 300W per channel at 4 ohms in a stereo Leach type amplifier,
Old 14th August 2006, 07:30 AM   #6
Hi, thanks for the reply, I'm looking at a 8 Ohm design which would give about 250w.
Old 14th August 2006, 07:40 AM   #7
I have seen this seller's data before.
The regulation when driving 1kVA seems very high (suspiciously high).
I queried it with the Seller but got no sensible response.
I think the transformer would do audio duty, just don't expect to get 600watts out of the amplifier.
Singa,
how did you work out (or not work out) the DC rail voltage?
regards Andrew T.
Old 14th August 2006, 09:20 AM   #8
djk is offline djk
djk's Avatar
"I'm looking at a 8 Ohm design which would give about 250w."
In that case I would use something like a transformer rated at 55-0-55 at full load. AndrewT is right, the regulation figures don't seem good, especially for that much weight.
Old 14th August 2006, 09:23 AM   #9
quasi is offline quasi  Australia
quasi's Avatar
The maximum power using this transformer is;
Available DC voltage = 46v - 5% regulation - 1v (diode bridge) * 1.414 = +/- 60v DC.
Even a great DC filtering section and solid state amplifier with transistor output stages will lose around 5 volts at full power, so the maximum voltage swing will be 55 volts.
55v * 0.707 = 38.8vrms = 190 watts into 8 ohms. Dynamic power will greater.
And this I believe is the at best result.
My $0.02
Cheers
Q
Old 14th August 2006, 01:09 PM   #10
you could use Quasi's predictions to guess at how many channels you could run off the one transformer.
I think you could run three channels into 8ohms each, or just about two channels into 4ohms each.
Into 4ohms the supply rails will sag but this can be partially compensated by increasing the smoothing capacitor bank up from the usual 2mF to 3mF per Apk of output current/channel to 3mF to 4mF/Apk/channel.
I seriously recommend a separate rectifier and smoothing bank to each channel fed from the common pair of secondary windings.
regards Andrew T.
A good tube amplifier power supply Jean-Paul_2 Tubes / Valves 23 18th June 2009 11:19 PM
Good 300 W 8 Ohm power amplifier darkm4n Solid State 28 22nd January 2004 02:23 PM
good battery for amplifier power supply? cowanrg Parts 0 20th September 2003 11:47 PM
What makes a good audio power transformer? nania Solid State 94 29th April 2003 02:27 PM
Good price on huge power transformer for power amp. G Solid State 3 15th September 2002 01:23 PM
Page generated in 0.10230 seconds (77.57% PHP - 22.43% MySQL) with 10 queries
