Old 13th August 2006, 05:23 PM   #1
Default Leach super Amp heatsinks
hi,
Can anyone advise me on what rating heatsinks I should use on the driver transistors in a Leach superamp? I built a standard Leach and used 10C/W sinks on Q16 and Q17 and they only just get warm; should I use the same on Q26 and Q27? Or do they share the power, so I could use something smaller?
Planning on using MJE15032/3, and MJE340/350 for the preceding stage, as these work well in the standard Leach amp.
Thanks,
Chris
Old 13th August 2006, 05:52 PM   #2
what Pq are you planning?
Identify your Iq and Vce for each device.
r52 & r54 share the voltage almost equally between q16 & q26.
10C/W will allow about 2W and 20C/W about 1W.
Depending on your Vcc and Iq you may be able to share one 20C/W between the pair (q16+q26).
regards Andrew T.
Old 14th August 2006, 04:06 PM   #3
acenovelty's Avatar
The Prof. recommends:
Heat sinks for Q16 and Q17 are Aavid 5741B (DigiKey HS111-ND).
The newer Aavid part # is Part Number - 574102B00000.
Thermal Resistance 23.20
Thermal resistance value is based on a 75°C rise in natural convection.
This is what it looks like.
Two people can keep a secret if one of them is dead.
Old 14th August 2006, 08:45 PM   #4
Thanks!
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 02:15 PM
Leach Super Amp HELP ... Ahmad_tbp Solid State 22 28th December 2009 05:44 AM
leach super amp with +/- 78V lenti Solid State 1 21st July 2002 03:00 PM
I need some help with super Leach amp! supernet Solid State 5 22nd April 2002 09:27 PM
Leach amp vs super Leach amp supernet Solid State 0 21st February 2002 10:16 PM
Page generated in 0.07753 seconds (70.68% PHP - 29.32% MySQL) with 11 queries
