Old 13th August 2006, 06:37 AM   #1
ben goh is offline ben goh  Singapore
Send a message via AIM to ben goh Send a message via Yahoo to ben goh
Default bias setting
Hi
Need help and clearance.
In idle mode with 4 ohms load , the bias setting on the emitter
resistor 0.5 ohms is 10mv. If a 1 khz of 200 mv is fed, the bias
went up to 40mv with a constant output signal of 5.6 volts a.c.
Is the bias normal?
Thank you for any feedback.
Old 13th August 2006, 07:15 AM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Ben,
This looks fine to me. It is normal that the current increases when signal is applied. Of course, without knowing the amp, it's impossible to tell if the values are within specs.
/Hugo
Old 13th August 2006, 10:07 AM   #3
Hi Ben,
it is normal to measure the bias with the speaker disconnected.
Otherwise any DC output offset will send some current into your load.
Then the bias currents in the opposite resistors will be different. So neither reading (voltage) gives a true bias current.
When your multimeter is reading 40mV is it the same for both emitter resistors?
Can your multimeter differentiate between DC bias voltage and AC output current (and voltage) flowing through the emitter resistor?
regards Andrew T.
Old 13th August 2006, 01:54 PM   #4
Hi
I have two digital meter to test. One on the bias and the other
on the output. Both on d.c volts range. 0 volts dc is achieved
at the output and when I cut the 1khz tone, the bias went back
to 10mv. It is the same with the others. My power output are all
NPN transistors. Please enlightened me. how to measure the
ac output current.
Old 14th August 2006, 01:53 AM   #5
anatech is offline anatech  Canada
anatech's Avatar
Hi Ben,
Bias current is not normally measured dynamically. Bias current is always measured with no signal and no load (open).
Your current reading will increase with signal as Hugo said. How much is not known. It will depend on your meter and the amp. The impedance (not resistance) of your load at whatever frequency is important.
If you wish to measure the AC current in the load, you can use a current clamp for your oscilloscope (around one lead to the speaker), a sensing load in series with the load resistor or an accurate, resistive load (non-inductive). For the resistive load, just measure the AC voltage, most Digital meters are inaccurate over a couple hundred Hz. An Agilent or Fluke brand is what I could trust. Almost no other brand is worthwhile for this. An oscilloscope may not be accurate enough.
-Chris
Old 14th August 2006, 03:17 AM   #6
Hi Chris
Thanks for the infor.
I am using Fluke 79 meter for the test.
Without load and signal, the bias across each resistor is at
constant 10mv.
I presumed the amp should be working fine.
Old 14th August 2006, 04:07 PM   #7
anatech's Avatar
Hi Ben,
I'd say so.
I good test is to measure the bias cold, then after about 5 min. Then heat the heasink up with tones or music into a dummy load, then disconnect and measure the bias current with the heatsink hot. I like to see a slight reduction in bias current. Most times you will see a slight positive change. That's okay too. A large positive change means that the amp may go into thermal runaway if ventillation is reduced and music is played loud. This is really pretty common in a household.
-Chris
Old 14th August 2006, 04:18 PM   #8
I second that. Reducing bias as the amp overheats can only help longevity.
The increase in distortion might even become noticeable and tell the listen to switch off.
regards Andrew T.
Old 14th August 2006, 04:26 PM   #9
anatech's Avatar
Hi Andrew,
Not that much of a reduction!
When you test an amplifier, the top cover may be off. Also the amp is not on a shelf. Once th ecover is on, and the amp has less airflow, that negative change may become a positive one. An increase in bias current can only become worse once installed.
Interestingly, most Marantz amplifiers exhibit a slight negative change in bias current with increasing temperature. Looking at the circuits, you know this was intentional. I feel they made the correct choice. The change in bias is never enough to affect the distortion measurements.
If I design an amplifier, I think one test will be the installation horror of those small stereo stands with the glass doors.
-Chris
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
Testing and setting bias on Zv9 sts9fan Pass Labs 2 23rd September 2008 07:45 PM
Setting Bias kptseng Solid State 9 8th March 2008 01:56 AM
Luxman B12 bias setting kro5998 Solid State 15 16th August 2006 07:22 PM
Problems with bias setting Cicero Solid State 5 21st January 2005 08:01 AM
Page generated in 0.11392 seconds (81.03% PHP - 18.97% MySQL) with 10 queries
