My VU meter shows 8W for normal listening. How many Watts do you listen to ? |
#2 | |
#3 |
Right
#4 |
Sounds like a couple of years from now you'll be averaging 100W or more.
If those are true VU meters and you're listening to that level on an average basis your hearing is in jeopardy. Assuming typical 88 dB/W sensitivity that's around 97 dB. Far too loud for any extended listening. I'm usually well under a watt with speakers around 89 dB/2.83V. Sure, I'll rock out and approach your number, but only for a few minutes a day. |
#5 | |
To me it sounds reasonable. My meters show a maximum of about 30W peak in the bass region (Peerless XLS 10 subwoofer, 88db/1W/1m), and that's still just "fairly loud", not ear-distorting. Sek. |
#6 |
Hi Ashley,
For really good tunes, I may hit 10W on a VU meter cal'd into 8 R with 4R speakers. Occasionally I may even clip around 225W (I figure giving 1.5 * the 150W rating, Marantz. I'm low.). That is mighty loud. Normal music may show around a watt or less. -Chris |
#7 | |
#8 |
just happened to be measuring voltages yesterday. DMM readings varied 100mV to 300mV when at conversation level. About 300mV to 600mV was conversation stopping. about 1V to 2V was damned loud. All on 88db 8ohm speakers. I don't know how far the peaks exceeded these readings.
regards Andrew T. |
#9 | |
Hi Andrew,
SPL will depend on your room and treatment of surfaces. -Chris |
#10 |
I had scope attached while listening, when really enjoying music i had peaks up to 12v (18watts into 4ohm), normal listening levels are below 1 watt. The ~20watts are loud enough to bug my neighbors...
My speakers are ~89db, my room ~5*6m. Mike |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| Listen to my sub | mikee55 | Subwoofers | 29 | 28th August 2007 10:02 AM |
| What do you listen to? | nanl2053 | Music | 3 | 16th December 2006 11:43 AM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Listen to this.. | ecliptica | Music | 0 | 28th January 2004 08:36 AM |
| Page generated in 0.10741 seconds (76.95% PHP - 23.05% MySQL) with 11 queries |
