Old 11th August 2006, 07:10 AM   #1
Default biasing or quescient current setting
I have an amplifier and has a pair of (2sc3182 & 2sa1265) which are bipolar transistors, can someone help me how to set the best quescient current for them ? the brand of the amplifier I have is SILVER which now this company is ONKYO, I dont have schematics for it !
thanks
ron
Old 11th August 2006, 07:41 AM   #2
it depends very much on the design and the heatsink dissipation capacity.
More Iq means higher case (Tc) and junction (Tj) temperatures.
Higher temperatures reduce the safety margin before blowing up your output stage.
Go easy, and don't be tempted to experiment with high temperature heatsinks (Ts) without the technical information to support your decisions.
regards Andrew T.
Old 11th August 2006, 12:51 PM   #3
is there a safely or basic quescient current ? I read that it is from 50mA to 100mA. Can I draw a load line for my output transistor and set the resulting current as my quescient current ?
thanks
ronald
Old 11th August 2006, 03:06 PM   #4
load lines belong to Tube (valve) design.
50mA will cause a lot of heating from each output device.
Do not guess and hope! You might destroy your output stage.
regards Andrew T.
Old 11th August 2006, 11:38 PM   #5
anatech is offline anatech  Canada
anatech's Avatar
Hi Ronald,
The normal bias current for production amplifiers will lie between 10 and 30 mA. Most falling in the 15 ~ 20 mA range. Mosfet designs will run 50 ~ 100 mA.
Harmon Kardon ran very hot and had larger heatsinks. It ran a higher bias current.
You are completely safe setting your bias current somewhere between 15 and 20 mA per device. Distortion will not decrease by running the unit any hotter.
-Chris
Aleph 2 ac current setting ? ndhennin Pass Labs 7 9th May 2007 09:43 PM
need help setting bias current... SkinnyBoy Solid State 10 6th May 2005 12:17 AM
sam's 300W or eti-466 :setting quiescent current bigpanda Solid State 6 20th April 2005 07:32 AM
having trouble setting quiesent current? tinkerbell Solid State 35 11th April 2005 11:34 PM
Setting bias current of Aleph 5 billy Pass Labs 1 8th August 2002 04:16 AM
Page generated in 0.06024 seconds (84.16% PHP - 15.84% MySQL) with 10 queries
