Old 9th August 2006, 08:03 PM   #1
Fixup is offline Fixup  United States
Default Do electrolytic caps need bypass?
This might be an old question, but I have something new here.
I opened a Panasonic FM 1000uF/6.3V. I believe FM has the latest technology, because this series is only 1 or 2 years old. FM has so far the lowest ESR and highest working frequency among similar aluminum electrolytics.
As you can see from the picture, the two leads are placed at the middle of the two foil strips. This way, high-frequency signal has a very short path. The major inductance is indeed from the two leads only, as pointed out by many recent articles.
So, my question is: when we use such an ultra-low-ESR cap for power bypassing, do we still need to use a film or ceramic to bypass it? Note the ESR is only 0.04ohm.
Many articles have talked about the ESR and ESL issues about electrolytic caps related to traditional bypass and paralleling techniques. They claim that there is no need to bypass these new electrolytic caps. Even worse, resonance will happen due to the very low ESR of these new caps. But none of them is based on an internal picture. Does this picture add more support to those claims?
Old 9th August 2006, 08:27 PM   #2
FastEddy's Avatar
Default do these electrolitic caps need [additional] bypass?
Probably not, butt
... running a plastic / tantlum / ceramic / other type cap in parallel with the 'lectro types is good for some applications (like the downstream side of a voltage regulator or PS feed on to circuit boards) = thus "snubbing" the bigger cap = brightening it up = better high freq. (HiFi?) response, sometimes.
... butt you knew that, already.
paralleling film caps with electrolytic caps jarthel Power Supplies 381 10th March 2012 08:13 AM
Electrolytic to film - Retain the bypass in coupling app? HaflerFreak Parts 17 3rd March 2008 08:43 AM
bypass caps for bypassing mylar caps? crippledchicken Multi-Way 4 27th February 2008 04:24 AM
Electrolytic Caps jhead Parts 0 21st April 2004 10:11 PM
Electrolytic Caps MRehorst Swap Meet 5 12th December 2002 03:45 PM
Page generated in 0.07668 seconds (69.81% PHP - 30.19% MySQL) with 11 queries
