hello guys,
please I would like to know some comments here or some unbias ideas from the experts of amplifiers here. im no expert on amplifiers but a general idea from you guys would help a lot.
which would be much better between these two designs....it will be mainly used for driving bass speakers
first...a 4 steps class H, almost the same as Ion use... the voltages from the transformer are as follows.. 35V -73V-111V -141V
it puts out 1800 watts @ 8ohms
second ...same as lab gruppen design, TD
THANK YOUYou have missed this one:
Power amplifier
and this one:
Audio power amplifier for supplying electric power to a load by switching of power supply voltage
and this one:
Amplifier with signal-dependent voltage supply source
and another:
Composite bridge amplifier
and by the way put all this in the some bag:
Pulse-width modulated, linear audio-power amplifier
Amplification circuit
Audio frequency power amplifiers
Power supplying circuit for supplying a voltage to a driving circuit
Composite bridge amplifier with output overload and thermal protection
Audio frequency power amplifiers with actively damped filter
Low power consuming balanced transformer less amplifier device
Amplifying circuit with power supply switching circuit
High back emf, high pressure subwoofer having small volume cabinet, low frequency cutoff and pressure resistant surround
Method and apparatus for improving power transfer efficiency of an amplifier system
High efficiency power amplifying apparatus
Switching amplifier for generating continuous arbitrary waveforms for magnetic resonance imaging coils
Integrated audio amplifier
hehehe!! ...it is like a joke...
