Is there a rule for the value for emitter resistor Is there a rule for the value for emitter resistor - diyAudio
Old 6th August 2006, 07:48 AM   #1
ostie01 is offline ostie01  Canada
Default Is there a rule for the value for emitter resistor
Hi, I want to buy some non inductive emitter resistor for a power amplifier project. I've seen value from .1 Ohm to 1 Ohm. Is there a rule to choose this value. .22 Ohm and .33 Ohm look like to be a very standard value. But why some use .1 Ohm and others use 1 Ohm. The value I'm looking are for an approx. 200w power amp.
Thanks.
Old 6th August 2006, 08:00 AM   #2
how many pairs in each channel?
To drive 4 ohm or 8ohm?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th August 2006, 08:03 AM   #3
Hi, thanks for the reply:
This amp will drive 8 Ohm load and 8 pairs per channel
Old 6th August 2006, 08:39 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Maximum output power???
Old 6th August 2006, 08:58 AM   #5
65 Vdc for approx. 250w RMS
Old 6th August 2006, 09:01 AM   #6
based on 8pairs into 8ohm then I think 0r39 would work.
A highish value to force some balancing action between the 8pairs.
When all eight are paralleled then the effective emitter reisistor is about 0r05 in each half.
I think you will find that a single pair of emitter resistors are in the range 0r0 to 0r33. When paralleling the outputs you find that the designer increases the values as the pairs multiply.
250W from +-65V supply rails might not happen. Even 200W from PSU rails at that voltage will require a very stiff supply.
regards Andrew T.
Old 6th August 2006, 09:03 AM   #7
Hi, thank you very much. I can buy those on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
but they are .47 Ohm, can't find any .39 Ohm
Old 6th August 2006, 09:11 AM   #8
john curl is offline john curl  United States
john curl's Avatar
Smaller is better. About .22 would be best for you.
"Condemnation without Examination is Prejudice"
Old 6th August 2006, 09:13 AM   #9
Smaller is better
provided the output stage remains stable.
regards Andrew T.
Old 6th August 2006, 09:17 AM   #10
diyAudio Member RIP
A good read of Doug Selfs "Power Amplifier Design" is recommended.
Basically it depends on the accuracy and stability of the biasing,
but .22 is a good value for most designs. 0.1 is better but only
with a good sized heatsink and accurate biasing such that thermal
runaway is not an issue.
As AT says generally multiple output pairs the values are typically
increased to end up with the same effective emitter resistance,
though theorectically I can't see why this is done.
(Possibly there are stability issues, that is as you add pairs to
the output stage current gain is increased, which is pegged back
by increasing the emitter resistances, but then again 4 output
pairs are going to need an additional pre-driver stage, which
complicates stability issues no end, compared to no pre-driver.)
With 4 pairs and 0.47 you will end up with an effective resistance
of 0.12, so there is no reason at all why it won't work well, especially
if the pairs are there to dissapate power and swing decent current
into decent impedance loads. If the pairs are there in an attempt
to swing very high currents into low impedance loads then possibly
0.22 would work better.
/sreten.
Is there a rule for the value for emitter resistorHide this!Advertise here!
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
Dual Emitter Resistor glen65 Solid State 4 29th June 2006 02:55 AM
Emitter resistor values?? Zero Cool Solid State 18 24th February 2005 01:51 AM
where is the emitter resistor? homer09 Solid State 9 21st January 2004 07:38 AM
Copyright ©1999-2017 diyAudio
