Old 6th August 2006, 02:54 AM   #11
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, Mark,
What info (what measurement data) can you get from this Curve Tracer?
I saw this in the net. Do you have any idea what brand/model this one is?
Old 6th August 2006, 03:26 AM   #12
These old transistor curve tracers basically test the transistors in a common emitter configuration. They step the base current through a range of steps and sweep the collector to emitter voltage and display the collector current. Each curve on the plots you have shown is for a specific base current. (You set this with a knob on the curve tracer; you probably know this.) I don't think it matters if the transistor are Ge or Si.
Since the input to the DUT is current, not voltage, it won't work for FETs.
Old 6th August 2006, 03:44 AM   #13
It can be externally modified with a 1K resistor to measure fets. Did it for decades!
Old 6th August 2006, 03:59 AM   #14
It can also do testing in common base config. as well. Then the emitter can be stepped with either voltage or current.
The 575 manual is here....
The user guide is here...
The user guide is particuluarly interesting!!
There was also a model for Vacuum Tubes!
Mark
KSA-100 WIKI
Old 28th January 2010, 06:26 PM   #15
jackinnj's Avatar
Found this 575 tracer on youtube: YouTube - Delco R-1233 All-American-5 tube radio powered up on TEK575 curve tracer - 28 Watts
Old 28th January 2010, 07:05 PM   #16
llwhtt is offline llwhtt  United States
Is anyone still using these? I picked one up a few years ago, needed a bunch of 6AN8s and 6AL5s. Ordered the tubes and they are still sitting on the self. I know where a couple of the 175s (high current adapter) are and wonder if it's worth picking one of those up. Matching transistors is a big subject on this forum and I wonder if the 575 is the way to do it.
Craig
Old 28th January 2010, 07:10 PM   #17
jackinnj's Avatar
I have a 576 which was received in sad shape -- but I've gotten it working (with a bit of patience.)
Old 31st January 2010, 12:46 PM   #18
jackinnj's Avatar
Now here's an Agilent tester/tracer which would really impress the ladies:
YouTube - Agilent B1505A Curve Tracer & Power Device Analyzer_Flory_5m30s.MP4
Old 31st January 2010, 01:58 PM   #19
Default 175
@llwhtt
Is it possible to share some info on the 175s
I do have and use a 575 and would like to get a high current adapter.
Thanks in advance
Old 31st January 2010, 04:07 PM   #20
Nice thread
Made a copy of the manual and guide for my 575 that has been sitting on the shelf for years.
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Tektronix 370 Curve Tracer - ease of use? PB2 Equipment & Tools 0 20th November 2007 04:12 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
Copyright ©1999-2013 diyAudio
