Hi
I've noticed recently my ancient Kenwood C1 Basic Stereo Control pre-amp has developed a hiss on one channel on analogue replay. I use my recently refurbished Quad 405, together with either a step-up transformer or a dc powered phono pre-pre. I've tried both step-up devices as well as the Quad elsewhere in my setups and these are dead-quiet - even at high volumes. I therefore suspect the Kenwood pre causing the hiss. This pre-amp has both mm and mc inputs and when in use, I use the mm input plus the step-up device for mc cartridges. Does anyone perhaps know where to start looking inside the Kenwood for this problem? bulgin |
#2 |
Hi
So sorry! Some more diagnosing discovered the problem. It's not the Kenwood - it is the Lentek pre mc phono thingie. I have other step-up devices here which I can use while I fix this problem. Thanks for your attention! bulgin |
| Hiss but no hum... | RockysDad | Tubes / Valves | 13 | 5th April 2009 05:35 PM |
| Hiss From An Ampli Channel | Calamaro | Solid State | 13 | 20th September 2008 01:50 PM |
| SI T-amp - bad hiss in one channel | toolkit | Class D | 7 | 30th November 2006 12:47 AM |
| T-Amp hiss/crackle in channel | nehpets | Class D | 19 | 10th October 2005 06:34 PM |
| hiss | jaudio | Chip Amps | 21 | 6th March 2005 05:02 PM |
| Page generated in 0.06417 seconds (66.20% PHP - 33.80% MySQL) with 10 queries |
