If i try to remove the output coil on my NAD3020 power amplifier, could it means that the amp will blow?
I know that is is there to secure stability in a NFB amp, but what does it actually do? Is it for extreame cases and special speaker cables? All speakers do have a coil af input for the woofer. Some amplifiers does not have this coil....Pass, Hiraga Class A, etc.....why? |
#2 |
It is mainly to damp the effects of a capacitive run of speaker cable, ie long cable runs, to prevent oscillation. In most cases leaving it out will do no harm.
Why remove it though? |
#3 |
just follow me for a moment. NAD sell very competitively priced amps. The designer decided his amp did not need a Thiel network on the output. The sales department said the amp would sell better if a Thiel network was added and would leave more margin for profit by allowing NAD to sell the amp at a higher price. I think not.
regards Andrew T. |
#4 |
The way I see it, in a consumer market amp, they have to cater for all kinds of events, such as the user having 10 metre cables and such nonsense.
DIY or enthusiast amps such as Pass's amps know that the user is going to be (fairly) sensible and not do such things. Whether there's any audible difference between the two is another matter. I usually add them "just in case". |
#5 |
miss this output filter....that coils with paralell resistance.
Maybe simulators are crazy, but i am afraid that it really does some effect in performance. regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
#6 | |
Account Disabled
Depends on construction of coil...and choice of values, of course. |
#7 |
In the real world, this coil rejects the extra phase shifting caused by adding components to the output such as complex reactive loads and long strands of wire. Having said this I digress to Mike B in post 35 of this thread: Amp distortion
and also rt7085 for post 46.
All the trouble I've ever been in started out as fun...... |
#8 |
Coils are expensive components. If the manufacturer of an amp was absolutely certain that the amp couldn't oscillate under any imaginable load condition, it would skip the coil. Serious manufacturers are probably cautious, though, so the cases where the coil is really needed may be rare, but on the other hand, they may not. It depends on the particular amp.
#9 |
Thank you all by the informs..they are always usefull.
regards, Carlos
#10 |
Sometimes people ask me if I have an extra cigarette. I examine the pack carefully pretending to count. I then say, "No, there are no extras".
| EV SP12C with too-low output and too-high coil DCR... | jon_010101 | Multi-Way | 2 | 21st June 2009 09:31 PM |
| Output coupling - Choke-coil method? | danielle | Tubes / Valves | 3 | 15th February 2006 09:57 PM |
| Page generated in 0.09886 seconds (76.45% PHP - 23.55% MySQL) with 12 queries |
