Old 4th August 2006, 07:38 AM   #1
Default encoder volume control
hi guys!
has someone a schematic of a volume control using a rotary encoder and a digital potentiometer?(if possible without microcontroller aid...)
thanx!
Old 4th August 2006, 08:18 AM   #2
i found this one...
http://www.edn.com/contents/images/278837f1.pdf
any other experience?
Old 4th August 2006, 11:03 PM   #3
nonoise is offline nonoise  South Africa
Have a look at Maxim's MAX5440
Old 6th August 2006, 09:04 PM   #4
yes, already seen, but it has just 32 positions...i'd like to have at least 128...it will be great to have the same ic but with more positions...
Old 7th August 2006, 05:32 AM   #5
Rather than the quad decoder, I'd use a micro controller to read the rotary encoder and drive a digital audio pot such as the PGA2311 or PGA2310.
Old 7th August 2006, 07:14 AM   #6
yes, I know that using a micro everithing will be possible and easier, but i've passed long time without programming a PIC so...i don't remember practically anything!!
Old 7th August 2006, 09:21 AM   #7
hmm...i've seen the pga2311 characteristics...sounds pretty good...bikedude, maybe can you post schematic and pic program?? (or ANYONE ELSE WHO USE IT!!!)
do you also use an lcd to display the attenuation?
Old 7th August 2006, 09:59 AM   #8
awpagan is offline awpagan  Australia
raikkonen
good idea for keeping digital noise out of a preamp.
have thought about controlling a pga* without a clock or pic.
havn't found a way yet, but there are a lot of smarter people on here than me.
also why the pga2311?, the pga2310 has +/-15v analogue, better headroom.
allan
ps the other pga.
Digitally controlled preamp/headphone amp
Indecision makes the world gone round.
Maybe
Old 7th August 2006, 11:13 AM   #9
pga2311 simply because has better THD and i don't need so much headroom...5v is enough...probably i must shift on a microcontrolled system...
Old 7th August 2006, 12:53 PM   #10
Pjotr's Avatar
What I know of a simple to use quadrature decoder is the HCTL2000. It decodes directly a 2 phase quadrature pulse encoder and outputs a 8 bit digital word.
If you hook up this to a relay ladder attenuator ….. you can do without a micro controller.
Cheers
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Optical Rotary Encoder Volume Control unit using the Grayhill 62P DJ Exprice Everything Else 17 1st January 2008 08:50 PM
How to use the Rotary Encoder to control the cs3310 ? cac liu Digital Source 11 24th July 2007 11:32 AM
Digital volume control w/rotory encoder (no MC) gmphadte Digital Source 17 8th October 2004 07:23 AM
Page generated in 0.09234 seconds (77.87% PHP - 22.13% MySQL) with 10 queries
