I bought 80pcs of 2SK129 (diff jfet) from ebay so long time ago, now I can't find any datasheet or schematic for them.
Where can I find a link for use this device ? , I'll compare both NPD5566, 2SK332, 2SK389, 2SK129 soon !!! Thanks analog guy |
#2 |
Apa Khabar??Are you sure they are 2SK129????
#3 |
Which, by an odd coincidence, is the number (109) on the drawing.
#4 |
Hi, mouser give NTE 2389 and Fairchild FDP3672 as replacement Not the same package but maybe close spec, Good luck
#5 |
2SK129 it's an n channel diff jfet with interesting package, 50V 10mA 300mW.
I have seen 2SK129 in NAKAMICHI CAR SUB-MONO-AMPLIFIER but I can't find a schematic for this one. |
#6 | |
can you describe the package more?
are these two seperate plastic to-92 package (or maybe a little bit taller than t0-92 package) devices wrapped togther in a piece of tin? if so they might be same pinout as 2sk146/2sj73. good luck, mlloyd1 edit: actually the answer is in your picture. it's been so long i forgot the japanese symbols for gate, drain and source. just find a japanese version of a known jfet datasheet and match the symbols Quote:
#7 |
we have no members here from Japan?
All the trouble I've ever been in started out as fun...... |
#8 |
I haven't found any data sheets either, but I'm working on a Sansui G-7500 that needs two 2SK129s. If you need copies of that amp section let me know.
Can you provide a source for 3 or 4 FETs? Thanks JP |
#9 |
Jeff Pedelty :
OK, How many do you want ? I already tested both 2SK389 & 2SK129, I loved 2SK129 with TR cascode circuit. I also used it instead of 2SK389BL on PASS ONO, it's very good for MM section Thanks analog guy |
#10 |
If I could get four, that would be great, in case I toast a couple on my first try.
Are you looking for schematics to use these in? Thanks, Jeff |
| ML 27 output problem/ schematic quest | Corvus corax | Solid State | 0 | 20th February 2008 04:43 AM |
| Marantz PM7000 problem /schematic | Juko | Solid State | 2 | 5th December 2007 07:06 PM |
| Subwofer Filter Schematic Problem | hernanstafe | Parts | 1 | 16th March 2007 09:15 AM |
| Musical Fidelity F16 problem/Schematic | Smiffy | Solid State | 8 | 10th December 2006 04:39 PM |
| schematic | homertooties | Solid State | 1 | 15th November 2006 01:48 AM |
| Page generated in 0.09787 seconds (80.44% PHP - 19.56% MySQL) with 11 queries |
