JLH 10W audio amp help with parts substitutions
Old 2nd August 2006, 10:47 PM   #1
kiram9 is offline kiram9  United States
Default JLH 10W audio amp help with parts substitutions
Im new here, but i just tried building my own version of the JLH 10W class A amplifier shown in figure 3 of
http://sound.westhost.com/jll_hood.htm
I had to make some parts substitiutions, Basically I
1. Subsitituted the output transistors (MJ480s) for 2N3055's
2. substituted the 2N3906 for a 2N2907
Substitued the 2n697 for a 4401 NPN transistor
I ran a spice model using thesubstituted parts using LT's switchercadIII and it looked like it would work no problem, but when I prototyped it, I found that at about 15 volts, there would be some sound, but it would be somewhat distorted.
Also when I brought up the voltage to around 22 volts, which is where I ran the simulation, the idle current rose to about .8 amps, what was predicted in the simulation, but the audio level faded away to nothing, (unpredicted).
So I have an amp that makes noise, and not much else. The Oscilliscope shows that when the voltage is too low, (around 10 volts) there is clipping on the upper half of the signal, and when it is too high, there is too much clipping on the lower half of the signal...
Any help would be appreciated, I am a little confused with this design, as the modifications I have made to it under simulation show that there should be no effect, but it does not work.....
Old 3rd August 2006, 07:50 AM   #2
latala is offline latala  United Kingdom
I can only advise you to check wiriong and parts as I have built this amp many times with similar parts always with good results !
regards Trev
Old 3rd August 2006, 08:05 AM   #3
rpapps is offline rpapps  Antarctica
Hi Kiram9
<Quote>
</Quote>
According to my Towers Transistor Selector book, 2N3906 is NPN and 2N2907 is PNP. You should take another look at suitable substitutes.
Cheers
Rob
Old 3rd August 2006, 09:21 AM   #4
I have 2n3906 as the PNP complement to 2n3904
Have you found the web site with all the JLH updates and transistor substitutions?
regards Andrew T.
Old 3rd August 2006, 10:24 AM   #5
Hi Andrew
Yes, you are right.
I must have read the next line, 2n3907.
My eyesight is really getting bad.
Part of the reason I am retired from this sort of work.
My apologies to Kiram9.
I guess it's time I retired from the field.
Cheers
Rob
Old 3rd August 2006, 12:22 PM   #6
Dont retire!!!
Get glasses it a real pain i find it hard to read part nos myself !
Regards Trev
Old 3rd August 2006, 03:37 PM   #7
glasses aren't enough for me, I have an eyeglass (+5D), a magnifier (+3D) on helping hands and a strong halogen spot.
regards Andrew T.
Old 4th August 2006, 12:56 AM   #8
Hi
I'm using all the aids Andrew mentioned but my problem is Macular Degeneration and whilst it's progress can be slowed, I will eventually lose sight unless a heart attack gets me first.
Cheers
Rob
Old 6th August 2006, 10:59 PM   #9
Thanks for your advice, Im still playing with it and I have it working a little better than before... I think my biggest problem is the radio shack parts, which i have already learned, usually have really strange values. Thanks for your advice, I tried building it twice, and I double checked everything, since its not the design, I might try a similar design to see if something else works. I will keep you posted.
Old 6th August 2006, 11:08 PM   #10
Yes Please persist Its a worthwhile design. Its performance far outways its small component count !Just think how chuffed you will be when you hear it working correctly.
Best of luck.
Regards Trev
JLH 10W audio amp help with parts substitutionsHide this!Advertise here!
GFA-555 parts upgrade/substitutions? Mac_Hath Solid State 104 3rd February 2017 03:20 PM
Trying to source 8700uf @ 56V or substitutions CountryScience Parts 2 17th June 2009 09:24 PM
Tube DI Help, Please: Substitutions slor Tubes / Valves 0 12th April 2008 03:20 AM
Ono semi substitutions and other Q's sbear Pass Labs 3 3rd February 2006 07:24 AM
Help with transistor substitutions trwh Solid State 8 10th September 2002 05:49 PM
