Old 1st August 2006, 09:24 AM   #1
felix42 is offline felix42  Germany
Default Single LED VU-Meter-like indicator
Hi everybody,
I am looking for a circuit that modulates the brightness of a single LED somehow proportional to the signal level (preferably taken from the preamp output).. It doesn't have to be accurate at all, this is just for eye candy.
I think they use this type of display a lot on bass amps and i think it must be similar to the clipping indicator circuits you see around here.
Can somebody point me in any direction here?
Thanks in advance!
Old 1st August 2006, 10:46 AM   #2
Frank Berry's Avatar
felix42,
You might try something like this. It's simple.
Trim the value of the feedback resistor to obtain enough gain to drive the LED.
Use a bi-polar power supply. + and - 15 volts will be good.
Frank
Frank
Old 1st August 2006, 08:09 PM   #3
destroyer X's Avatar
Default I think that a limiting resistor, a zener diode and one led
I think this will fit your need.
And the best way is to do it in a experimental way...to see the ligth modulation if fits your needs.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine.
Old 2nd August 2006, 08:59 AM   #4
Looks good, i'm going to try it out today.
Thanks for your help!
felix
Old 2nd August 2006, 09:08 AM   #5
Default Hi Felix, this is a thread that may be intersting to you
http://www.diyaudio.com/forums/showt...046#post716046
aufwiederlehsen
Karl
Old 2nd August 2006, 12:53 PM   #6
cpemma is offline cpemma  United Kingdom
Here's one that appeared in a Maplin magazine about 20 years ago. I've made single level versions to indicate danger to some 15W outdoor speakers I have. Runs off the speaker power, so audiophreaks beware.
Old 2nd August 2006, 12:56 PM   #7
Default Cpemma, this circuit works fine...very old really
But it is beeing used inside many good brand speaker around the world, including now a days studio monitors.
regards,
Carlos
Old 2nd August 2006, 01:01 PM   #8
Stripboarded unit
Old 2nd August 2006, 01:44 PM   #9
There's also a LB1443N "vu-meter" IC, 5 LEDs and simpler/cheaper than LM3915/6 circuits. The NAD3020 schematic linked nearby shows how they combine a signal from both speaker channels.
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 05:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
Clipping Indicator scott_jcp Chip Amps 2 5th April 2005 01:27 PM
Page generated in 0.09204 seconds (81.18% PHP - 18.82% MySQL) with 11 queries
