Class d sub
Class d sub
Old 8th December 2002, 03:23 PM   #11
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Class d sub
It is not easy to build a class d from discrete components. Firstly, you need an extremely fast sawtooth or triangle wave. That usually requires an opamp at least. You need a comparator to generate the PWM there's another high speed opamp. After that you need under/over sampling protection etc etc and then you have the discrete output that all the circuits have. In other words you still have to have chips unless you make up discrete opamps...but these are not really in the signal path (apart from the comparator). You shouldn't really take noise into consideration (by comparing discrete/chip) since you are totally dismantling the signal anyway! You will get far better results from an H-bridge driver or dedicated Class D driver...and it'll be a whole lot safer!
Gaz
Old 9th December 2002, 08:30 AM   #12
hacknet is offline hacknet  Singapore
i will look into class h
Old 9th December 2002, 09:38 AM   #13
phase_accurate is offline phase_accurate
hi hacknet
The subwoofer-modules i meant in an earlier post are made by the German manufacturer RCM Akustik.
They seem to be quite cool (in more than one sense) but they don't come cheap.
The 300 Watt one is about 300 Euros for example.
http://www.rcmakustik.com/eng/rcm_rahmen.htm
look under Products => Detonation => Datasheet
Charles
Old 9th December 2002, 08:12 PM   #14
Electro is offline Electro
Go to
http://www.classd.org/
Mueta chips looks very interesting for electrostatic loudspeakers.
Class d subHide this!Advertise here!
1500W RMS Class D PCB - which Class D Driver Chip is it ? mosfetsound Class D 11 1st April 2011 11:17 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Copyright ©1999-2017 diyAudio
