Do I need to heatsink if I install 40A Schottky 250V - PS of Rotel RB991
Old 30th July 2006, 06:39 PM   #1
dtm1962 is offline dtm1962  Canada
Default Do I need to heatsink if I install 40A Schottky 250V - PS of Rotel RB991
I have a bunch of On-Semi MBR40250 schottky power diodes in TO220 case style.
My RB991 power Amp (200W per channel) has dual PS (sharing a Common Xformer) and uses 2 BR154 (one for each channel) which are 15A 400V standard Power Diode Bridge.
The DC Rails are 70V and the Rail Fuses are 6.3A SloBlow and the Amp consumes a total of 550W (~750 VA). It has a 1.2KVA transformer.
I was going to make up a bread board using 4 MBR40250 Schottky per channel.
Assuming that the Amp is operating at 6 Amps @70 VDC = 420 VA
at maximum power (assuming the worse case), the diodes have a Forward drop of 0.6 at 6A & 70 C temp which translates into 3.6W of dissipation that the TO220 case has to handle.
Is this asking to much for a non-heatsinked Power Diode in a TO220?
Any help would be appreciated!.
Thanks,
Dan
Old 30th July 2006, 07:14 PM   #2
poobah is offline poobah  United States
poobah's Avatar
Yes... this is too much without a sink...
TO-220 devices top out at 1-2 Watts for dissispation naked in free air. You do need some heat sink... not alot. Some sort of a clip-on jobby should work for you.
You should also look at surge rating for the old diodes and make sure your new surge rating is comparable.
Old 31st July 2006, 08:50 PM   #3
EWorkshop1708 is offline EWorkshop1708  United States
heatsinks are good, use them, your diodes will last a lot longer
Old 2nd August 2006, 01:29 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Agree
Do I need to heatsink if I install 40A Schottky 250V - PS of Rotel RB991Hide this!Advertise here!
Service Manual/ schematic for Rotel ROTEL RHCD-10 Michi CD player Staykov Digital Source 9 1st March 2016 10:40 AM
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
Regenerating the 250V Mains andynehan Class D 7 1st March 2007 11:26 AM
Rotel RB991 schematic needed Samuel Jayaraj Solid State 2 25th April 2005 01:15 PM
where can i get a T3.15/250V fuse??? clipper10 Parts 1 30th June 2003 07:12 AM
