Onix OA21 + SOAP Compatibility
Old 1st August 2006, 06:09 AM   #11
sparkle is offline sparkle
sparkle's Avatar
complete preamplifier with mm,mc and line
mm, mc is to the left of this pcb and line is to the right
power supply is completely separated in another box (SOAP2 power supply).....
Old 1st August 2006, 06:10 AM   #12
sparkle's Avatar
complete package - left up is preamplifier - right up is psu for the preamplifier and at the bottom is power amp
Old 1st August 2006, 06:11 AM   #13
sparkle's Avatar
other view - ame thing
Old 1st August 2006, 06:13 AM   #14
sparkle's Avatar
oa601 - power amp - back
Old 1st August 2006, 06:14 AM   #15
sparkle's Avatar
complete power amplifier from inside - left filtering capacitors, and two dual regulators, right - power amp board and transformer
File Type: jpg oa601_complete internals_resize_resize.jpg (97.7 KB, 291 views)
Old 1st August 2006, 06:15 AM   #16
sparkle's Avatar
pcb board from the power amp itself with the output transistor mounted to the bottom of the amplifier
File Type: jpg oa601_power amplifier_resize_resize.jpg (84.4 KB, 232 views)
Old 1st August 2006, 06:16 AM   #17
sparkle's Avatar
better look at the regulator of the power amplifier
Old 1st August 2006, 09:57 AM   #18
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Hmmmmm i will go direct to you to make an offer.
Will be one amplifier and dollares.
Let`s see if we can produce one Escambo.... that is the name of this kind of business in my country.... going parts, amplifiers, money, fruits, bicicle, television...and many things, to obtain a higher price thing.
I will mail to you soon.
regards,
Carlos
Old 1st August 2006, 11:15 AM   #19
sparkle's Avatar
Carlos - why do you need my Onix when you have all the nice amplifiers at your home you could not possibly listen to it - my God you have at least 5-10 working amps right now - my poor Onix will not work at all
kidding right
best regards
Old 1st August 2006, 12:26 PM   #20
Default I have anything considered very good in the commercial range
Within your power limits to compare with others i have here.
All i have are many Sound Systems, the Kits assembled (the are wonderfull) and something too much modern compared with some designs i have assembled here.
I have to find something with the age of your equipment, to be a sample related good unit of this period of time.
This way i will see if the designer used the best possible capabilities of some decade amplifier design.
But i will not pay 700 Euros!.... what do you think in 500 inside Escambo method?
Go direct to me, otherwise this thread will be moved.
regards,
Carlos
Onix OA21 + SOAP CompatibilityHide this!Advertise here!
Onix & soap needs a re-cap fatmarley Parts 28 7th December 2013 08:07 AM
ONIX OA21 and SOAP Connection cocktailpiano Solid State 1 22nd November 2009 09:44 PM
onix oa21 + soap. mangoy Parts 3 1st July 2009 12:15 AM
Output of Onix Soap PS kptseng Solid State 2 16th December 2005 12:12 AM
