I need to build a volume control. Which is the common apporach use a pot' feeding a fixed gain amplifier or no pot with pot' variable feedback resistor (gain) ? Also reliable brands for pot's ? ALPS, Noble. any others ? |
#2 |
You can do it either way. I've seen Music Fidelity (UK) use the two-wire variable resistor in a feedbak loop to adjust gain. I worry about changing the GBP or frequency response with gain setting. I personally, don't like that approach and would rather use a fixed gain stage feed a potentiometer and take the attenuated signal off of the wiper.
P.S. Spectrol makes good pots too. (pricey!)
".........These go to eleven" |
#3 |
Or go for stepped attenuator,a little bit expensive but sounds great.
#4 |
Hey Ashley, build yourself one of these, you'll never go back to a mechanical pot again.
Lightspeed Attenuator a new passive preamp Cheers George |
#5 | |
#6 | |
Leo read the whole thread, all 17 pages, the answer is there. Cheers George |
| variable capacitor volume control | lochness | Tubes / Valves | 11 | 21st June 2008 09:39 AM |
| Variable Voltage Volume control | jkeny | Power Supplies | 4 | 10th February 2008 09:13 PM |
| Negative Feedback Gain Control | gni | Solid State | 22 | 3rd November 2007 11:14 AM |
| Variable power supply to control gainclone volume? | MWP | Chip Amps | 11 | 9th July 2004 08:53 PM |
| Using a variable resistor in the feedback loop. | darren01 | Chip Amps | 9 | 30th December 2003 10:05 AM |
| Page generated in 0.08015 seconds (73.03% PHP - 26.97% MySQL) with 10 queries |
